After restart the server, the OPC UA from Ignition not start
UaException: status=Bad_ConnectionClosed, message=connection closed
at org.eclipse.milo.opcua.stack.client.transport.uasc.UascClientMessageHandler.channelInactive(UascClientMessageHandler.java:155)
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelInactive(AbstractChannelHandlerContext.java:245)
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelInactive(AbstractChannelHandlerContext.java:231)
at io.netty.channel.AbstractChannelHandlerContext.fireChannelInactive(AbstractChannelHandlerContext.java:224)
at io.netty.handler.codec.ByteToMessageDecoder.channelInputClosed(ByteToMessageDecoder.java:390)
at io.netty.handler.codec.ByteToMessageDecoder.channelInactive(ByteToMessageDecoder.java:355)
at io.netty.handler.codec.ByteToMessageCodec.channelInactive(ByteToMessageCodec.java:118)
at io.netty.channel.DefaultChannelPipeline$HeadContext.channelInactive(DefaultChannelPipeline.java:1429)
at io.netty.channel.DefaultChannelPipeline.fireChannelInactive(DefaultChannelPipeline.java:947)
at io.netty.channel.AbstractChannel$AbstractUnsafe$8.run(AbstractChannel.java:822)
at io.netty.util.concurrent.AbstractEventExecutor.safeExecute(AbstractEventExecutor.java:163)
at io.netty.util.concurrent.SingleThreadEventExecutor.runAllTasks(SingleThreadEventExecutor.java:404)
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:462)
at io.netty.util.concurrent.SingleThreadEventExecutor$5.run(SingleThreadEventExecutor.java:897)
8.0.0-beta0 (b2018110513)
Azul Systems, Inc. 11.0.1
Reinstall the Ignition from last file from inductiveautomation, but same error:
Using:
Version: 8.0.0-beta0 (b2018112202)
Is this a UA connection to another server or is it the “loopback” connection to the local Ignition OPC UA server? Can you upload the logs here or send them to support?
The server is the Loopback, with Ignition OPC UA, I have one more server UA using a kepware, but I couldn’t configure using the encryption, need to keep without encryption, because the certificate show at Kepware, don’t correspond with server, so the connection not work.
