I have an error trying to open a file with the function system.net.openURL
My code is:
filePath='C:\Users\l.abdallah.ext\Desktop\20201120_134830_AlarmStatusTable.xlsx'
system.net.openURL("file:" + filePath)
Error:
java.io.IOException: java.io.IOException: Cannot run program "command.com": CreateProcess error=2, , The system cannot find the file specified
Ignition 8.0.12
Windows 10 x64
Thanks you
Try escaping your backslashes, python. Right now it’s reading your filePath as:
C:\Users\l.abdallah.ext\Desktop�01120_134830_AlarmStatusTable.xlsx
filePath='C:\\Users\\l.abdallah.ext\\Desktop\\20201120_134830_AlarmStatusTable.xlsx'
print filePath
Also, I believe you need double forward slashes after file:.
system.net.openURL("file://" + filePath)
https://docs.inductiveautomation.com/display/DOC79/system.net.openURL
thanks for the answer guys, but I still have the problem.
Try a simpler path, like c:\\temp\\new.txt
i think it’s java problem
File "<event:mouseClicked>", line 92, in <module>
at java.base/java.lang.ProcessBuilder.start(Unknown Source)
at java.base/java.lang.Runtime.exec(Unknown Source)
at com.inductiveautomation.ignition.client.util.BrowserLauncher.browse(BrowserLauncher.java:644)
at com.inductiveautomation.ignition.client.util.BrowserLauncher.openURL(BrowserLauncher.java:557)
at com.inductiveautomation.factorypmi.application.script.builtin.VisionNetUtilities.openURL(VisionNetUtilities.java:67)
at com.inductiveautomation.factorypmi.application.script.builtin.VisionNetUtilities.openURL(VisionNetUtilities.java:46)
java.io.IOException: java.io.IOException: Cannot run program "command.com": CreateProcess error=2, El sistema no puede encontrar el archivo especificado
at org.python.core.Py.JavaError(Py.java:552)
at org.python.core.Py.JavaError(Py.java:543)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:521)
at org.python.core.PyObject.__call__(PyObject.java:480)
at org.python.core.PyObject.__call__(PyObject.java:484)
at org.python.pycode._pyx37.f$0(<event:mouseClicked>:92)
at org.python.pycode._pyx37.call_function(<event:mouseClicked>)
at org.python.core.PyTableCode.call(PyTableCode.java:171)
at org.python.core.Py.runCode(Py.java:1614)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:779)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:206)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:297)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:57)
at com.sun.proxy.$Proxy58.mouseClicked(Unknown Source)
at java.desktop/java.awt.AWTEventMulticaster.mouseClicked(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Caused by: java.io.IOException: Cannot run program "command.com": CreateProcess error=2,The system cannot find the file specified
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
... 44 more
Caused by: java.io.IOException: CreateProcess error=2,The system cannot find the file specified
at java.base/java.lang.ProcessImpl.create(Native Method)
at java.base/java.lang.ProcessImpl.<init>(Unknown Source)
at java.base/java.lang.ProcessImpl.start(Unknown Source)
... 57 more
Ignition v8.0.12 (b2020042115)
Java: Azul Systems, Inc. 11.0.6
Hi , did you find a solution? I have the same problem, it used to work fine before.
What version of Ignition and Windows are you using (full version including patches if possible)? Did you install a Windows update recently?
Thanks for fast reply. We are currently working on igntion 8.1 with windows server 2019 up too 1809. We recently update to the latest igntion as well as updating oir windows server.
What version of Windows is the client or designer that is running this function? It doesn’t matter as much what Windows version the gateway is running on.
Hi, we are running the client on windows server 2019 also and accessing it via remote desktop app on an android tablet.
windows server 2019 standard
Hi, a friend found a way to work around the problem try this:
system.util.execute([‘explorer.exe’, ‘‘selectedfilepathhere’’])
Let me know if it works!
