Can you make some sense of the following error? This one project will not open. Other projects open just fine.
52952.txt (4.37 KB)
52952.txt (4.37 KB)
Are you trying to open it with Java 7?
Yes, but my other projects open fine. What do you suggest?
Ignition 7.2.x isn’t 100% compatible with Java 7 - This particular project is probably using one of the incompatible bits while the other projects aren’t.
You can either:
a) Use Java 6
b) Upgrade Ignition. I believe the latest 7.3 and beyond are all compatible.
I went back to Java 6 on that PC and it works fine now. Java 7 did work fine on that project until the latest Java update.
Thanks for the help!
