I get the following error when ever I try to open a project.
java.lang.NullPointerException
at java.awt.Container.remove(Unknown Source)
at com.inductiveautomation.ignition.designer.gui.StatusBar.removeDisplay(StatusBar.java:225)
at com.inductiveautomation.factorypmi.designer.model.ObjectHolder.shutdown(ObjectHolder.java:2161)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$LoadedModule.shutdown(IgnitionDesigner.java:2135)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.loadProject(IgnitionDesigner.java:814)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler$30.openProject(IgnitionDesigner.java:1854)
at com.inductiveautomation.ignition.designer.ProjectDialog$5.run(ProjectDialog.java:313)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
Ignition v7.1.1 (b5078)
Java: Sun Microsystems Inc. 1.6.0_20
