Ignition 8.3.0
Sometimes when opening views, it gets stuck on loading. Closing and reopening the view seems to fix it.
13:03:46.936 [Render Thread: 475b30c1-0a4b-4d44-8301-40313ae8e223] WARN Perspective.Designer.Workspace -- No designer store found on window!
13:03:46.943 [AWT-EventQueue-0] ERROR Perspective.JavaJsBridge -- Unexpected error dispatching pipe mode change.
java.lang.NullPointerException: Cannot read field "path" because the return value of "com.inductiveautomation.perspective.designer.api.DesignAdapter.getDeepSelection()" is null
at com.inductiveautomation.perspective.designer.workspace.ViewResourceEditor.onPipeModeChange(ViewResourceEditor.java:260)
at com.inductiveautomation.perspective.designer.workspace.ViewEditorJsBridge.lambda$onPipeModeChangeInternal$8(ViewEditorJsBridge.java:134)
at java.base/java.security.AccessController.doPrivileged(Unknown Source)
