Error opening Views sometimes in Designer requiring Designer restart
v8.1.5
Our IT recently “encouraged” me to start using the Ignition Designer inside of a VM (VMWare Player).
I haven’t seen this before on my base, but seem to be getting this quite regularly now inside my VM. I’m connected to a VPN within the VM if it’s relevant and I get it while having the VM open continuously i.e. throughout the day not after sleeping it etc.
Incidentally, it seems to happen more when i’m not using the VM and have it running in the background and come back to it.
14:49:57.000 [AWT-EventQueue-0] ERROR com.inductiveautomation.ignition.client.util.gui.ErrorUtil - null
java.util.concurrent.TimeoutException: null
	at java.base/java.util.concurrent.CompletableFuture.timedGet(Unknown Source)
	at java.base/java.util.concurrent.CompletableFuture.get(Unknown Source)
	at com.inductiveautomation.perspective.designer.workspace.ViewResourceEditor.getObjectForSave(ViewResourceEditor.java:434)
	at com.inductiveautomation.perspective.designer.workspace.ViewResourceEditor.getObjectForSave(ViewResourceEditor.java:63)
	at com.inductiveautomation.ignition.designer.tabbedworkspace.ResourceEditor.commit(ResourceEditor.java:160)
	at com.inductiveautomation.perspective.designer.workspace.ViewResourceEditor.notifyDeactivated(ViewResourceEditor.java:528)
	at com.inductiveautomation.perspective.designer.workspace.PerspectiveWorkspaceListener.editorSelected(PerspectiveWorkspaceListener.java:73)
	at com.inductiveautomation.ignition.designer.tabbedworkspace.TabbedResourceWorkspace$3.stateChanged(TabbedResourceWorkspace.java:115)
	at java.desktop/javax.swing.DefaultSingleSelectionModel.fireStateChanged(Unknown Source)
	at com.jidesoft.swing.JideTabbedPane$IgnoreableSingleSelectionModel.fireStateChanged(Unknown Source)
	at java.desktop/javax.swing.DefaultSingleSelectionModel.setSelectedIndex(Unknown Source)
	at java.desktop/javax.swing.JTabbedPane.setSelectedIndexImpl(Unknown Source)
	at java.desktop/javax.swing.JTabbedPane.setSelectedIndex(Unknown Source)
	at com.jidesoft.swing.JideTabbedPane.setSelectedIndex(Unknown Source)
	at java.desktop/javax.swing.JTabbedPane.setSelectedComponent(Unknown Source)
	at com.inductiveautomation.ignition.designer.tabbedworkspace.TabbedResourceWorkspace.open(TabbedResourceWorkspace.java:242)
	at com.inductiveautomation.perspective.designer.workspace.nav.ViewNode$DelayedOnSelect.run(ViewNode.java:402)
	at com.inductiveautomation.ignition.client.util.EDTUtil$ProcessQueue.run(EDTUtil.java:127)
14:49:57.013 [AWT-EventQueue-0] ERROR Perspective.Designer.Workspace - Could not unregister the bridge's edit action handler for a view on deactivate
java.lang.IllegalArgumentException: missing event subscriber for an annotated method. Is com.inductiveautomation.perspective.designer.JavaJsBridgeEditActionHandler@7e6a30e9 registered?
	at com.google.common.eventbus.SubscriberRegistry.unregister(SubscriberRegistry.java:111)
	at com.google.common.eventbus.EventBus.unregister(EventBus.java:201)
	at com.inductiveautomation.perspective.designer.workspace.design.BrowserPanel.onDeactivate(BrowserPanel.java:858)
	at com.inductiveautomation.perspective.designer.workspace.ViewResourceEditor.notifyDeactivated(ViewResourceEditor.java:532)
Exception in thread "AWT-EventQueue-0" java.lang.IllegalStateException
	at com.teamdev.jxbrowser.deps.com.google.common.base.Preconditions.checkState(Preconditions.java:492)
	at com.teamdev.jxbrowser.internal.CloseableImpl.checkNotClosed(CloseableImpl.java:34)
	at com.teamdev.jxbrowser.zoom.internal.ZoomImpl.level(ZoomImpl.java:44)
	at com.inductiveautomation.perspective.designer.workspace.design.BrowserPanel.syncZoomIndicator(BrowserPanel.java:846)
	at com.inductiveautomation.perspective.designer.workspace.design.BrowserPanel.onActivate(BrowserPanel.java:821)
	at com.inductiveautomation.perspective.designer.workspace.ViewResourceEditor.notifyActivated(ViewResourceEditor.java:515)
	at com.inductiveautomation.perspective.designer.workspace.PerspectiveWorkspaceListener.editorSelected(PerspectiveWorkspaceListener.java:80)
Edit: it just happened again. I came back to my VM after 10 mins, opened a View, clicked on a component and then the View white screened and got the errors above in the console. This also popped up (Message tab is blank)
The 'timeout exception' is a symptom of this actual root cause:
The JxBrowser instance running inside the designer has disappeared.
Unfortunately, there's not a lot for you to do as an end user. We're in the process of testing an upgrade of JxBrowser to the latest version, which will hopefully help with its overall stability and performance, but until it lands there's not really anything to do as an end user.
Thanks for the info. So the only way to fix for now for us is by restarting the designer? No way to reload the browser manually?
Yeah, that’s pretty much it. You may want to make sure there are no rogue processes hanging around after you close the designer to be sure.
Not sure if this is relevant, but I have noticed this doesn’t happen when using VMs from AWS (I think I select SSD and not HDD when selecting drive type). But on Azure, it happens all the time when running the designer on the same VM as the gateway. I think it is a resource or hard drive latency issue. I never see this issue when running gateway and designer on my laptop or on physical servers.
