Good Morning.
In Ignition 8.0.14, I have developed an application that uses several images, but they are not very heavy (from 15 kb to 60 kb). If I run the application in the designer (F10), it runs without problems. But when running on a client PC, many images do not load or load randomly, and sometimes the error “OutOfMemoryError: Java heap space” occurs, even though the process is only using 400 MB of RAM.
In the project properties the maximum client memory has been increased to 4GB, but this does not solve the issue.
Best Regards.
