I’m getting an error when I run this script, it’s printing a report.
Code:
[code]report = event.source.parent.getComponent(‘Report Viewer’)
report.print(None, 0)
timer = event.source.parent.getComponent(‘Timer’)
timer.running = 1[/code]
Error:
[code]Traceback (most recent call last):
File “event:actionPerformed”, line 2, in
at com.inductiveautomation.reporting.components.ReportViewer.print(ReportViewer.java:1021)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
java.lang.NullPointerException: java.lang.NullPointerException
at org.python.core.Py.JavaError(Py.java:495)
at org.python.core.Py.JavaError(Py.java:488)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:204)
at org.python.core.PyObject.__call__(PyObject.java:422)
at org.python.core.PyObject.__call__(PyObject.java:426)
at org.python.core.PyMethod.__call__(PyMethod.java:139)
at org.python.pycode._pyx7.f$0(<event:actionPerformed>:5)
at org.python.pycode._pyx7.call_function(<event:actionPerformed>)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.Py.runCode(Py.java:1275)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:624)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:583)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:170)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:265)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:55)
at com.sun.proxy.$Proxy20.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.AbstractButton.doClick(Unknown Source)
at com.inductiveautomation.factorypmi.application.components.PMIButton.doClick(PMIButton.java:68)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186)
at org.python.core.PyObject.__call__(PyObject.java:387)
at org.python.core.PyObject.__call__(PyObject.java:391)
at org.python.core.PyMethod.__call__(PyMethod.java:109)
at org.python.pycode._pyx6.f$0(<event:internalFrameActivated>:3)
at org.python.pycode._pyx6.call_function(<event:internalFrameActivated>)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:168)
at com.sun.proxy.$Proxy21.internalFrameActivated(Unknown Source)
at javax.swing.JInternalFrame.fireInternalFrameEvent(Unknown Source)
at javax.swing.JInternalFrame.setSelected(Unknown Source)
at javax.swing.JInternalFrame.show(Unknown Source)
at java.awt.Component.show(Unknown Source)
at java.awt.Component.setVisible(Unknown Source)
at javax.swing.JComponent.setVisible(Unknown Source)
at com.inductiveautomation.factorypmi.application.FPMIApp$RuntimeWindowOpener.openWindow(FPMIApp.java:1786)
at com.inductiveautomation.factorypmi.application.FPMIApp.openWindow(FPMIApp.java:1018)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities$5.run(NavUtilities.java:437)
at com.inductiveautomation.factorypmi.application.script.builtin.WindowUtilities.doGUIAction(WindowUtilities.java:707)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.openWindowImpl(NavUtilities.java:375)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.openWindow(NavUtilities.java:364)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:428)
at org.python.pycode._pyx5.f$0(<event:actionPerformed>:7)
at org.python.pycode._pyx5.call_function(<event:actionPerformed>)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
Caused by: java.lang.NullPointerException
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:186)
… 107 more
Ignition v7.8.0 (b2015101414)
Java: Oracle Corporation 1.8.0_65
[/code]
I’ll poke around a bit in the code and see if something pops out.
