Error project loading
Hello,
I'm getting this error message while trying to open my project. I was able to open last night but now getting this message. How can I reopen my project?
Error message;
java.lang.IllegalArgumentException: com.inductiveautomation.ignition.common.project.resource.ResourceNamingException: Cannot add child 'com.inductiveautomation.perspective/views/framework/header' to parent 'com.inductiveautomation.perspective/views/Framework'
at com.inductiveautomation.ignition.designer.project.ResourceTreeNode.addChild(ResourceTreeNode.java:252)
at java.base/java.util.ArrayList.forEach(Unknown Source)
at com.inductiveautomation.ignition.designer.project.ResourceTreeNode.(ResourceTreeNode.java:61)
at com.inductiveautomation.ignition.designer.project.DesignerProjectTreeImpl.createNode(DesignerProjectTreeImpl.java:144)
at com.inductiveautomation.ignition.designer.project.DesignerProjectTreeImpl.lambda$createNode$7(DesignerProjectTreeImpl.java:141)
at java.base/java.util.stream.ReferencePipeline$3$1.accept(Unknown Source)
at java.base/java.util.stream.ReferencePipeline$2$1.accept(Unknown Source)
at java.base/java.util.HashMap$KeySpliterator.forEachRemaining(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.copyInto(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
at java.base/java.util.stream.ReduceOps$ReduceOp.evaluateSequential(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.evaluate(Unknown Source)
at java.base/java.util.stream.ReferencePipeline.collect(Unknown Source)
at com.inductiveautomation.ignition.designer.project.DesignerProjectTreeImpl.createNode(DesignerProjectTreeImpl.java:142)
at com.inductiveautomation.ignition.designer.project.DesignerProjectTreeImpl.lambda$new$0(DesignerProjectTreeImpl.java:74)
at com.inductiveautomation.ignition.designer.project.DesignerProjectTreeImpl.(DesignerProjectTreeImpl.java:75)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$StartupProjectDialogHandler.lambda$new$2(IgnitionDesigner.java:2049)
Caused by: com.inductiveautomation.ignition.common.project.resource.ResourceNamingException: Cannot add child 'com.inductiveautomation.perspective/views/framework/header' to parent 'com.inductiveautomation.perspective/views/Framework'
at com.inductiveautomation.ignition.designer.project.ResourceTreeNode.addChildInternal(ResourceTreeNode.java:266)
at com.inductiveautomation.ignition.designer.project.ResourceTreeNode.addChild(ResourceTreeNode.java:250)
... 35 more
Ignition v8.1.25 (b2023021409)
Java: Azul Systems, Inc. 11.0.17
The "caused by" section three lines from the bottom is the reason but I don't know enough to help further.
As a workaround until someone else can help, you could try creating a new project and importing parts of that project one-by-one. I suspect that it might choke in the same way though.
framework and Framework? did you do some renaming?
  • Transistor new project and importing method is worked! thanks a lot! :pray:
  • victordcq I was changed same names and saved without problem yesterday but got this error message. Thanks to advice, problem solved :slight_smile:
ive never had a problem in ignition with names, but i know some other platforms that couldnt recognize just a capital change. maybe its something that happenes everywhere idk
Please mark that answer as the solution then!
