Error querying history density
I have had this problem in my gateway but I no longer have that database so I don’t know where the error is in my clients, it gives me information about a Tag but when I use the FIND tool absolutely nothing appears.
Could someone support me?
(id=b6cb19ff) Error querying history density. Tag history provider ‘FH_DataBase’ could not be found, or does not support history querying.
(id=277da8c) Error querying history density. Tag history provider ‘T1XX_Flex’ could not be found, or does not support history querying.
This forum post was turned into a support ticket.
For those curious what is going on here, the following error "Error querying history density. Tag history provider ‘X’ could not be found, or does not support history querying." means you have a tag referencing a database which no longer exists.
I'd double check your database connections & tag's storage provider to make sure these are the proper databases.
