From a S7-1500 I have to read the bits of the last two bytes of a DB (bytes 3848, 3849). Ignition cannot read those bits: tag quality is Unknown. Going to the kepware log I see the following reading error:
It seems that Ignition is telling Kepware to read 3 bytes from 3848: is there any reason for that?
My bits are defined by using a UDT as follows (StartByte=3848):
Any suggestion?
Thank you in advance
Regards
