Error reading tag properties from remote tag provider
I have an Ignition 8.0.2 gateway and a connected Ignition 7.9.4 gateway. I am trying to read tag properties from the connected v7 gateway and getting a NullReferenceException when reading the HistoryProvider, historicalDeadbandStyle and a UDT property.
This is my code sample:
private static final BasicProperty<InterpolationMode> DeadbandStyleProperty =
        new BasicProperty<>("historicalDeadbandStyle", InterpolationMode.class,
                InterpolationMode.Auto);
private static final BasicProperty<Object> UdtProperty =
        new BasicProperty<>("My User Defined Type", Object.class);
List<String> properties = List.of(
        WellKnownTagProps.HistoryProvider.getName(),
        DeadbandStyleProperty.getName(),
        UdtProperty.getName()
String tagPath = "";
List<TagPath> propertyPaths = properties.stream()
        .map(p -> TagPathParser.parseSafe(String.format("%s.%s", tagPath, p)))
        .collect(Collectors.toList());
List<QualifiedValue> values = tagManager.readAsync(propertyPaths).get();
Any idea what I am doing wrong?
IIRC, there were bugs in cross-version remote tag provider functionality well into the v8.1 series. You probably need to upgrade.
{ Well, since you are using a development version that became end-of-life as soon as v8.1 was released, you need to upgrade anyways. }
Thank you. Upgrading to v8.1.23 seems to have fixed it
