I ran into this problem, and if I saved the project, I would get an error saying something like, check that the Projects folder exists in the Projects directory
GatewayException: project not found: test_timer
caused by ProjectNotFoundException: project not found: test_timer
Ignition v8.1.38 (b2024030513)
Java: Azul Systems, Inc. 17.0.9
Detail Error
> com.inductiveautomation.ignition.client.gateway_interface.GatewayException: project not found: test_timer
> at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:360)
> at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:334)
> at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:287)
> at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:967)
> at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.pushProject(GatewayInterface.java:1000)
> at com.inductiveautomation.ignition.designer.project.PushTask.run(PushTask.java:19)
> at com.inductiveautomation.ignition.client.util.gui.ProgressDialog$TaskRunner.run(ProgressDialog.java:348)
> at java.base/java.lang.Thread.run(Unknown Source)
> Caused by: com.inductiveautomation.ignition.common.project.ProjectNotFoundException: project not found: test_timer
> at com.inductiveautomation.ignition.gateway.project.IgnitionProjectManager.lambda$getProjectProps$1(IgnitionProjectManager.java:165)
> at java.util.Optional.orElseThrow(null)
> at com.inductiveautomation.ignition.gateway.project.IgnitionProjectManager.getProjectProps(IgnitionProjectManager.java:165)
> at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.Projects.canEditProject(Projects.java:317)
> at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.Projects.push(Projects.java:194)
> at jdk.internal.reflect.GeneratedMethodAccessor74.invoke(null)
> at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(null)
> at java.lang.reflect.Method.invoke(null)
> at com.inductiveautomation.ignition.gateway.servlets.gateway.AbstractGatewayFunction.invoke(AbstractGatewayFunction.java:228)
> at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:435)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:523)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:590)
> at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
> at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1410)
> at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:764)
> at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1665)
> at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:527)
> at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:131)
> at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:578)
> at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:122)
> at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:223)
> at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1570)
> at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:221)
> at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1384)
> at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:176)
> at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:484)
> at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1543)
> at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:174)
> at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1306)
> at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:129)
> at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)
> at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:301)
> at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:51)
> at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:141)
> at org.eclipse.jetty.server.Server.handle(Server.java:563)
> at org.eclipse.jetty.server.HttpChannel.lambda$handle$0(HttpChannel.java:505)
> at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:762)
> at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:497)
> at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:282)
> at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:314)
> at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:100)
> at org.eclipse.jetty.io.SelectableChannelEndPoint$1.run(SelectableChannelEndPoint.java:53)
> at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.runTask(AdaptiveExecutionStrategy.java:416)
> at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.consumeTask(AdaptiveExecutionStrategy.java:385)
> at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.tryProduce(AdaptiveExecutionStrategy.java:272)
> at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.lambda$new$0(AdaptiveExecutionStrategy.java:140)
> at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:411)
> at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:969)
> at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.doRunJob(QueuedThreadPool.java:1194)
> at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1149)
> at java.lang.Thread.run(null)
Blockquote
GateWay Log Error Contents:
AuditManager 12Jun2024 14:51:06 Error getting project properties for audit.
at java.base/java.util.Optional.orElseThrow(Unknown Source)
at com.inductiveautomation.ignition.gateway.audit.AuditManagerImpl.getProfileForProject(AuditManagerImpl.java:255)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.Login.audit(Login.java:1589)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.Login.logout(Login.java:1555)
