"Error reading updated project" when saving project in designer
i started a new project on linux server
i imported views from an edge
i am trying to save the project and i got this massage
error reading updated project from gatewaythe
the massage details
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Post Error, error code = 413at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:360)at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:356)at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:481)at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:292)at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:287)at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:967)at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.pushProject(GatewayInterface.java:1000)at com.inductiveautomation.ignition.designer.project.PushTask.run(PushTask.java:19)at com.inductiveautomation.ignition.client.util.gui.ProgressDialog$TaskRunner.run(ProgressDialog.java:348)at java.base/java.lang.Thread.run(Unknown Source)
Ignition v8.1.48 (b2025042910)Java: Azul Systems, Inc. 17.0.14
How can i resolve this
Your error message is mangled, but the relevant bit survived - error code 413.
"Content too large" suggests either:
  1. Some middleware between your Linux server and wherever you're trying to save the project is rejecting the request
  2. Your project is genuinely too large for our default webserver settings, suggesting you're doing something catastrophically wrong like saving a massive binary file into your project. I've literally never heard of someone getting a 413 from Ignition specific code.
