I’m running Ignition 8.1.44 and recently removed an Edge Gateway connection from our central primary gateway. I deleted all existing connections on both ends and uninstalled the EAM agent from the Edge gateway since it’s no longer needed.
However, I’m still seeing the following error in other Edge logs every minute:
Any ideas on what might be causing this or how to stop it?
