I got an error while adding tag to the designer.
Look in the gateway to see if there’s a more detailed error to go with that.
Nothing in Logs page, are you sure?
Your designer probably had the provider in view and trying to add a tag for a none existing provider retrieves the exception.
Your screenshot suggests a corrupted internal database with that “newProvider”. You’ll need help from support to clean it up.
Hi Akrit,
I have same issue. did you end up fixing it? any information about it would be a great help.
Thanks.
