I have a simple script that is supposed to read the value from a dropdown component and print that value to the console. I get an error when I try to execute the script. This is on a view in a Perspective window.
processNum=self.getSibling('drpProcessSel').props.value
#stepNum=self.root.custom.currentStep
print processNum
#print stepNum
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last): File “”, line 2, in runAction AttributeError: ‘NoneType’ object has no attribute ‘props’
at org.python.core.Py.AttributeError(Py.java:207)
at org.python.core.PyObject.noAttributeError(PyObject.java:1032)
at org.python.core.PyObject.getattr(PyObject.java:1027)
at org.python.pycode._pyx0.runAction$1(:6)
at org.python.pycode._pyx0.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:171)
at org.python.core.PyBaseCode.call(PyBaseCode.java:308)
at org.python.core.PyFunction.function___call__(PyFunction.java:471)
at org.python.core.PyFunction.call(PyFunction.java:466)
at org.python.core.PyFunction.call(PyFunction.java:456)
at org.python.core.PyFunction.call(PyFunction.java:451)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:683)
at com.inductiveautomation.ignition.common.script.ScriptManager$ScriptFunctionImpl.invoke(ScriptManager.java:801)
at com.inductiveautomation.perspective.gateway.script.ScriptFunctionHelper.invoke(ScriptFunctionHelper.java:82)
at com.inductiveautomation.perspective.gateway.action.ScriptAction.runAction(ScriptAction.java:65)
at com.inductiveautomation.perspective.gateway.action.ActionDecorator.runAction(ActionDecorator.java:18)
at com.inductiveautomation.perspective.gateway.action.SecuredAction.runAction(SecuredAction.java:51)
at com.inductiveautomation.perspective.gateway.model.ActionCollection$ActionSequence$ExecuteActionsTask.lambda$call$0(ActionCollection.java:257)
at com.inductiveautomation.perspective.gateway.api.LoggingContext.mdc(LoggingContext.java:54)
at com.inductiveautomation.perspective.gateway.model.ActionCollection$ActionSequence$ExecuteActionsTask.call(ActionCollection.java:246)
at com.inductiveautomation.perspective.gateway.model.ActionCollection$ActionSequence$ExecuteActionsTask.call(ActionCollection.java:215)
at com.inductiveautomation.perspective.gateway.threading.BlockingTaskQueue$TaskWrapper.run(BlockingTaskQueue.java:154)
Caused by: org.python.core.PyException: Traceback (most recent call last): File “”, line 2, in runAction AttributeError: ‘NoneType’ object has no attribute ‘props’
