Error Running Query on Vision Client
Hello,
I am getting this error. Which to my limited understanding is saying The current user does not have the required rols for this operaton at com.inductiveautomation.ignition.client.gateway_interface.
How would I solve this?
Message: [componentName=Numeric Label,targetProperty=value] Error running query:
SQLQuery(query=SELECT Setpoint_Prod_Max_Flow FROM recipe_prod_table WHERE recipe_prod_ndx = 12, database=Historian_Database)@0ms
On: Processing.Root Container.Numeric Label.value
Time: Fri Apr 12 1:04:36PM
Severity: WARN
Logger: Vision.Binding.SQLPropertyAdapter
Stack Trace: java.lang.Exception: Error running query:
    at com.inductiveautomation.factorypmi.application.gateway.QueryManager$QueryExecutor.run(QueryManager.java:311)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Error executing function 'RunQuery': The current user does not have the required roles for this operation.
    at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:360)
    at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:334)
    at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:287)
    at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.runLimitQuery(GatewayInterface.java:893)
    at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.runQuery(GatewayInterface.java:864)
    at com.inductiveautomation.factorypmi.application.gateway.SQLQuery.execute(SQLQuery.java:50)
    at com.inductiveautomation.factorypmi.application.gateway.QueryManager$Query.execute(QueryManager.java:668)
    at com.inductiveautomation.factorypmi.application.gateway.QueryManager$QueryExecutor.run(QueryManager.java:308)
    ... 1 common frames omitted
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayResponse$GatewayThrowable: The current user does not have the required roles for this operation.
    at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:431)
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:523)
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:590)
    at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
    at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1410)
    at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:764)
    at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1665)
    at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:527)
    at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:131)
    at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:578)
    at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:122)
    at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:223)
    at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1570)
    at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:221)
    at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1384)
    at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:176)
    at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:484)
    at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1543)
    at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:174)
    at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1306)
    at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:129)
    at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)
    at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:301)
    at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:51)
    at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:141)
    at org.eclipse.jetty.server.Server.handle(Server.java:563)
    at org.eclipse.jetty.server.HttpChannel.lambda$handle$0(HttpChannel.java:505)
    at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:762)
    at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:497)
    at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:282)
    at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:314)
    at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:100)
    at org.eclipse.jetty.io.SelectableChannelEndPoint$1.run(SelectableChannelEndPoint.java:53)
    at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.runTask(AdaptiveExecutionStrategy.java:416)
    at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.consumeTask(AdaptiveExecutionStrategy.java:385)
    at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.tryProduce(AdaptiveExecutionStrategy.java:272)
    at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.lambda$new$0(AdaptiveExecutionStrategy.java:140)
    at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:411)
    at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:969)
    at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.doRunJob(QueuedThreadPool.java:1194)
    at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1149)
    at java.lang.Thread.run(null)
Take a look at the Project Permissions, in particular, Legacy Database Access.
That was it. I didn't even think about it on the project side. Thank you so much.
