Error saving tag changes to a Remote Tag Provider
I have Managed Tag provider running a Remote Gateway. I have have enabled setAllowTagCustomization on the provider. And I am able to modify tags inside that Tag Provider while I am accessing them from that Gateway’s designer.
On a different gateway, I have a Remote Tag provider set up to reference this same Managed Tag provider. I also set the Security Zone rules on the Remote Gateway to allow read/write of tags between this gateway and the remote gateway.
However, When I try to make a tag modification to the Remote Tag provider from the second gateway, I get the following access denied error.
ExecutionException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: java.lang.SecurityException: Access Denied. Remote tag editing is not allowed for provider 'myManagedTagProvider'.
	caused by GatewayException: java.lang.SecurityException: Access Denied. Remote tag editing is not allowed for provider 'myManagedTagProvider'.
	caused by ExecutionException: java.lang.SecurityException: Access Denied. Remote tag editing is not allowed for provider 'myManagedTagProvider'.
Ignition v8.1.2 (b2021020311)
Java: Azul Systems, Inc. 11.0.9
Here is Java that sets up the Managed Tag provider.
    private ManagedTagProvider createManagedTagProvider(String newProviderName) {
        ProviderConfiguration config = new ProviderConfiguration(newProviderName);
        config.setAllowTagCustomization(true);
        config.setPersistTags(true);
        config.setPersistValues(true);
        ManagedTagProvider newProvider = this.context.getTagManager().getOrCreateManagedProvider(config);
        newProvider.registerWriteHandler(null, (TagPath target, Object value) -> {
            if (isProtectedTag(target)) {
                return QualityCode.Bad_AccessDenied;
            return Send(target, value);
        return newProvider;
Any ideas what I might be missing here?
Read/write? Or Read/Write/Edit? There's a distinct permission for the latter.
That was it! I selected Read/Write in my Service Security settings instead of Read/Write/Edit. Thanks!
hi @dpitzer ,
What type of modifications can you make on your provider? I am trying to add a folder on the provider through designer but it would give me access denied error.
I am new on playing with managed tag provider and would appreciate the comment.
Thanks,
Can the tags be Read/Write/Edit on a Igniton Edge gw, from a Ignition Full gw?
As far as I know the answer to that is yes.
When I tried accessing the remote (central) tag provider from Edge, it wasn’t visible. However, from the central (full) Ignition gateway, I was able to view and create tags on the Edge tag provider, but I encountered the error: Bad_NotFound("Unknown provider. [CPW_Snowflake]").
Considering that Edge only supports one tag provider, what is the correct method for transferring tags from a central/full Ignition gateway to an Edge gateway?
Hi!
Does anyone know where i can find this setting in 8.3.3?
