With V7.4.1 and system.net.sendEmail, I’ve an annoying error while the message is well send to the recipient.
Any idea is welcome
The event is fire by a PropertyChange event :
if event.propertyName == "emailReport":
if event.newValue == 1:
tomail = event.source.getComponent('toEmail').text
#print tomail
report = event.source.getComponent('Report Viewer')
bytesPDF = report.getBytesPDF()
system.net.sendEmail("smtp.mydomain.com", "Ignition-automated-reports@mydomain.com", "Alarm Message", "text message", 0, [tomail], ["Rapport Alarmes.pdf"], [bytesPDF], 60000*5, "from@mydomain.com", "mypwd")
I’ve the following error :
File "<event:propertyChange>", line 7, in <module>
NameError: name 'email' is not defined
at org.python.core.PyException.fillInStackTrace(PyException.java:70)
at java.lang.Throwable.<init>(Throwable.java:181)
at java.lang.Exception.<init>(Exception.java:29)
at java.lang.RuntimeException.<init>(RuntimeException.java:32)
at org.python.core.PyException.<init>(PyException.java:46)
at org.python.core.PyException.<init>(PyException.java:43)
at org.python.core.PyException.<init>(PyException.java:61)
at org.python.core.Py.NameError(Py.java:246)
at org.python.core.PyFrame.getname(PyFrame.java:257)
at org.python.pycode._pyx1.f$0(<event:propertyChange>:9)
at org.python.pycode._pyx1.call_function(<event:propertyChange>)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.Py.runCode(Py.java:1261)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:537)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:152)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:260)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:55)
at $Proxy14.propertyChange(Unknown Source)
at java.beans.PropertyChangeSupport.firePropertyChange(PropertyChangeSupport.java:339)
at java.beans.PropertyChangeSupport.firePropertyChange(PropertyChangeSupport.java:276)
at java.awt.Component.firePropertyChange(Component.java:8248)
at sun.reflect.GeneratedMethodAccessor29.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at com.inductiveautomation.factorypmi.application.binding.util.DynamicPropertyUtil.firePropertyChange(DynamicPropertyUtil.java:246)
at com.inductiveautomation.factorypmi.application.binding.util.DynamicPropertyUtil.setPropertyValue(DynamicPropertyUtil.java:237)
at com.inductiveautomation.vision.api.client.components.model.AbstractVisionPanel.setPropertyValue(AbstractVisionPanel.java:116)
at com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.updateTarget(AbstractPropertyAdapter.java:275)
at com.inductiveautomation.factorypmi.application.binding.SimpleBoundTagAdapter.updateTarget(SimpleBoundTagAdapter.java:513)
at com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.updateValue(AbstractPropertyAdapter.java:240)
at com.inductiveautomation.factorypmi.application.binding.SimpleBoundTagAdapter.notifyTagChanged(SimpleBoundTagAdapter.java:479)
at com.inductiveautomation.factorypmi.application.binding.SimpleBoundTagAdapter.tagChanged(SimpleBoundTagAdapter.java:469)
at com.inductiveautomation.ignition.client.sqltags.impl.db.DatasourceTagManager$TagChangeListenerProxy.tagChanged(DatasourceTagManager.java:1054)
at com.inductiveautomation.ignition.client.sqltags.impl.ChangeNotifier.run(ChangeNotifier.java:38)
at com.inductiveautomation.ignition.client.sqltags.impl.db.BatchNotifier.run(BatchNotifier.java:78)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:682)
at java.awt.EventQueue.access$000(EventQueue.java:85)
at java.awt.EventQueue$1.run(EventQueue.java:643)
at java.awt.EventQueue$1.run(EventQueue.java:641)
at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:87)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:652)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Ignition v7.4.1 (b906)
Java: Apple Inc. 1.6.0_31
