I don’t think I have that many scripts in my project, but I’m getting a message saying the encoded string is too long.
[code]com.inductiveautomation.ignition.common.xmlserialization.SerializationException: IOException during serialization.
at com.inductiveautomation.ignition.common.xmlserialization.serialization.XMLSerializer.serialize(XMLSerializer.java:430)
at com.inductiveautomation.ignition.common.xmlserialization.serialization.XMLSerializer.serializeBinary(XMLSerializer.java:406)
at com.inductiveautomation.ignition.common.xmlserialization.serialization.XMLSerializer.serializeBinary(XMLSerializer.java:399)
at com.inductiveautomation.ignition.designer.scripteditor.ModuleEditor.serialize(ModuleEditor.java:415)
at com.inductiveautomation.ignition.designer.scripteditor.ModuleEditor.doApply(ModuleEditor.java:394)
at com.inductiveautomation.ignition.designer.scripteditor.ModuleEditor$3.actionPerformed(ModuleEditor.java:453)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$000(Unknown Source)
at java.awt.EventQueue$1.run(Unknown Source)
at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$2.run(Unknown Source)
Caused by: java.io.UTFDataFormatException: encoded string too long: 70506 bytes
at java.io.DataOutputStream.writeUTF(Unknown Source)
at com.inductiveautomation.ignition.common.xmlserialization.serialization.BinaryWriter.writeStringTable(BinaryWriter.java:87)
at com.inductiveautomation.ignition.common.xmlserialization.serialization.BinaryWriter.writeElement(BinaryWriter.java:63)
at com.inductiveautomation.ignition.common.xmlserialization.serialization.XMLSerializer.serialize(XMLSerializer.java:428)
… 42 more
Ignition v7.3.1 (b496)
Java: Sun Microsystems Inc. 1.6.0_26
[/code]
