I'm seeing lots of these in a gateway's wrapper log, but I don't see any errors/dropped history in the store and forward status overview:
INFO   | jvm 1    | 2023/03/03 11:57:36 | E [t.e.a.history                 ] [01:27:36]: Error storing tag history data
INFO   | jvm 1    | 2023/03/03 11:57:36 | java.lang.Exception: Unable to add data to memory buffer, buffer full.
INFO   | jvm 1    | 2023/03/03 11:57:36 | 	at com.inductiveautomation.ignition.gateway.history.stores.MemoryStore.insertInBuffer(MemoryStore.java:185)
INFO   | jvm 1    | 2023/03/03 11:57:36 | 	at com.inductiveautomation.ignition.gateway.history.stores.MemoryStore.syncdStoreData(MemoryStore.java:83)
INFO   | jvm 1    | 2023/03/03 11:57:36 | 	at com.inductiveautomation.ignition.gateway.history.stores.AbstractStore.storeData(AbstractStore.java:233)
INFO   | jvm 1    | 2023/03/03 11:57:36 | 	at com.inductiveautomation.ignition.gateway.history.stores.MultiStageStore.syncdStoreData(MultiStageStore.java:144)
INFO   | jvm 1    | 2023/03/03 11:57:36 | 	at com.inductiveautomation.ignition.gateway.history.DefaultStoreAndForwardEngine.storeData(DefaultStoreAndForwardEngine.java:145)
INFO   | jvm 1    | 2023/03/03 11:57:36 | 	at com.inductiveautomation.ignition.gateway.history.HistoryManagerImpl.storeHistory(HistoryManagerImpl.java:240)
INFO   | jvm 1    | 2023/03/03 11:57:36 | 	at com.inductiveautomation.gateway.tags.history.actor.HistoryActorFactory$DelayedEvaluationContainer.process(HistoryActorFactory.java:944)
INFO   | jvm 1    | 2023/03/03 11:57:36 | 	at com.inductiveautomation.gateway.tags.history.actor.HistoryActorFactory$DelayedEvaluationContainer.run(HistoryActorFactory.java:903)
INFO   | jvm 1    | 2023/03/03 11:57:36 | 	at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO   | jvm 1    | 2023/03/03 11:57:36 | 	at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
INFO   | jvm 1    | 2023/03/03 11:57:36 | 	at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
INFO   | jvm 1    | 2023/03/03 11:57:36 | 	at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO   | jvm 1    | 2023/03/03 11:57:36 | 	at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO   | jvm 1    | 2023/03/03 11:57:36 | 	at java.base/java.lang.Thread.run(Unknown Source)
How can I see what these are referring to? (also, are there any plans to make this more obvious in the logging?)
