Error system.db.runPrepUpdate
Hello,
I tried to enter in the changed value of a tag the following script:
valore = 110
system.db.runPrepUpdate(“UPDATE scd_command SET id_command_status = 25 WHERE cd_command = (?)”, [valore])
But when I change the value I get this error:
[b]Value Changed Error executing script.
File “tagevent:valueChanged”, line 17, in valueChanged
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:362)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:260)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(UPDATE scd_command SET id_command_status = 25 WHERE cd_command = (?), [110], , , false, false)
ERROR[/b]
I attach photos.
How can I fix this error?
You can fix it by supplying the database argument in the system.db.runPrepUpdate function call.
When the database argument is not supplied a project’s default datasource is used. That doesn’t work in this case because a Tag Event script is not associated with a project.
Best,
Thanks a lot!
I have one more question. I put in the script the name of the database connection (dscada_main) like this:
valore = 110 system.db.runPrepUpdate("UPDATE scd_command SET id_command_status = 25 WHERE cd_command = (?)", [valore] ,dscada_main)
This is the syntax:
system.db.runPrepUpdate(query, args, database, tx, getKey, skipAudit)
Parameters
String database - The name of the database connection to execute against. If omitted or “”, the project’s default database connection will be used.
But it gives me this error:
NameError: global name ‘dscada_main’ is not defined
ERROR
Can you help me?
Yes.
Use a string argument, like this:
valore = 110
system.db.runPrepUpdate("UPDATE scd_command SET id_command_status = 25 WHERE cd_command = (?)", [valore] ,"dscada_main")
Now it works.
Thanks a lot!
Andrea
