Good day, I have a problem with tag history data storing. I checked the history tag configuration on the Gateway, and everything seems fine, but in the logs, I have the following error message
com.microsoft.sqlserver.jdbc.SQLServerException: Invalid object name 'sqlth_drv'.
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:265)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.getNextResult(SQLServerStatement.java:1662)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.doExecutePreparedStatement(SQLServerPreparedStatement.java:615)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement$PrepStmtExecCmd.doExecute(SQLServerPreparedStatement.java:537)
at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:7417)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:3488)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeCommand(SQLServerStatement.java:262)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeStatement(SQLServerStatement.java:237)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.executeQuery(SQLServerPreparedStatement.java:456)
at org.apache.commons.dbcp2.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:122)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRPreparedStatement.executeQuery(SRConnectionWrapper.java:973)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper.runPrepQuery(SRConnectionWrapper.java:167)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.loadOrCreateSystemDetails(TagHistoryDatasourceSink.java:471)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.getSystemDetails(TagHistoryDatasourceSink.java:433)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.initialize(TagHistoryDatasourceSink.java:296)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:544)
