Error trying to create or save a project
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Creating project failed.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:328)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:302)
at com.inductiveautomation.ignition.designer.gateway.PriviledgedDesignerTask$GatewayMessageTask.execute(PriviledgedDesignerTask.java:426)
at com.inductiveautomation.ignition.designer.gateway.PriviledgedDesignerTask$TaskThread.run(PriviledgedDesignerTask.java:328)
at java.lang.Thread.run(Unknown Source)
Caused by: simpleorm.utils.SException$Jdbc: Executing INSERT INTO PROJECT_RESOURCES (PROJECT_RESOURCES_ID, ResourceId, ProjectId, Name, Documentation, ModuleId, ResourceType, SerializationVersion, Scope, Data, Published) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?) for [ProjectResourceRecord 15104 NewRecord Dirty1]
at simpleorm.sessionjdbc.SSessionJdbcHelper.flushExecuteUpdate(SSessionJdbcHelper.java:409)
at simpleorm.sessionjdbc.SSessionJdbcHelper.flush(SSessionJdbcHelper.java:376)
at simpleorm.sessionjdbc.SSessionJdbc.flush(SSessionJdbc.java:425)
at simpleorm.sessionjdbc.SSessionJdbc.flush(SSessionJdbc.java:410)
at simpleorm.sessionjdbc.SSessionJdbc.commitAndDetachDataSet(SSessionJdbc.java:351)
at com.inductiveautomation.ignition.gateway.project.ProjectManagerImpl.addProject(ProjectManagerImpl.java:147)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.runCreateProject(Gateway.java:964)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:389)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:769)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:585)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1125)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1059)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:52)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
at org.eclipse.jetty.server.Server.handle(Server.java:497)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:311)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:248)
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:540)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:610)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:539)
at java.lang.Thread.run(null)
Ignition v7.8.0 (b2015101414)
Java: Oracle Corporation 1.8.0_131
If restarting the gateway doesn’t improve the situation you may need to call support tomorrow morning.
Make sure you have a recent backup just in case. Either download on, or copy the db folder from the data directory wherever Ignition is installed.
Thanks for the suggestion, all ready restart the gateway but continue the same error.
