In trying to update a custom module in Ignition 7.9 I am getting the following error:
Cannot send messages on backup node
I am not finding any direction in the 70-line log message to identify where the problem is as everything else seems to be functioning and the Redundancy is showing as "Peer Connected" "Activity: Active" and "Sync: Good" on the status Overview page.
Can you post the full stack trace?
Are you trying to install the module on the backup?
I am installing it on the main gateway server.
java.lang.Exception: Cannot send messages on backup node.
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.executeTask(RedundancyManagerImpl.java:561)
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.executeTask(RedundancyManagerImpl.java:555)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.installModule(ModuleManagerImpl.java:646)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.installModule(ModuleManagerImpl.java:653)
at com.inductiveautomation.ignition.gateway.web.pages.config.ModuleInstallPage.eulaCertCheck(ModuleInstallPage.java:197)
at com.inductiveautomation.ignition.gateway.web.pages.config.ModuleInstallPage$1.onSubmitInternal(ModuleInstallPage.java:70)
at com.inductiveautomation.ignition.gateway.web.components.CsrfPreventingForm.onSubmit(CsrfPreventingForm.java:66)
at org.apache.wicket.markup.html.form.Form$9.component(Form.java:1248)
at org.apache.wicket.markup.html.form.Form$9.component(Form.java:1242)
at org.apache.wicket.util.visit.Visits.visitPostOrderHelper(Visits.java:274)
at org.apache.wicket.util.visit.Visits.visitPostOrder(Visits.java:245)
at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1241)
at org.apache.wicket.markup.html.form.Form.process(Form.java:923)
at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:769)
at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:702)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.apache.wicket.RequestListenerInterface.internalInvoke(RequestListenerInterface.java:258)
at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:216)
at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.invokeListener(ListenerInterfaceRequestHandler.java:240)
at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.respond(ListenerInterfaceRequestHandler.java:226)
at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:814)
at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:253)
at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:210)
at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:281)
at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:188)
at org.apache.wicket.protocol.http.WicketFilter.doFilter(WicketFilter.java:245)
at com.inductiveautomation.ignition.gateway.bootstrap.SRFilter.doFilter(SRFilter.java:80)
at org.eclipse.jetty.servlet.FilterHolder.doFilter(FilterHolder.java:201)
at org.eclipse.jetty.servlet.ServletHandler$Chain.doFilter(ServletHandler.java:1601)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:548)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:600)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1440)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1355)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
at org.eclipse.jetty.server.Server.handle(Server.java:516)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:487)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:479)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105)
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:555)
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:410)
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:164)
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034)
And this message appears in the main server logs?
Are you sure you're looking at the master?
What do the settings under Configure > System > Redundancy say? What about the Status overview and redundancy pages?
I don't know what happened but when I looked at those settings it looks like someone switched the master and the backup.
When I went to what I thought was the backup I was able to install the module.
Thanks.
