I’m getting the below error when trying to save my project…
Exception in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: Java heap space
Is there anything I can do? I’ve already exported my project. I’ve restarted the gateway a couple times as well, but I presume it’s the Designer memory that’s the issue?
Do you have any very intensive operations running? Say a python script that selects all the rows of a database table into a dataset, and the table is very big? I haven’t had the run out of Java Heap Space error when saving designer, but I’ve run into it in general and where a python script is holding onto a very large usually dataset object.
I was asleep, haha. It was 3am here when I posted my last reply, having woken up during the night. I left my laptop running just in case there was some magical answer, but sounds like there’ll be no magic today.
Actually, I’ll try opening another designer and copying the windows I’ve changed across.
Cheers
Edit: is there a way to see what the heap memory is? And why didn’t the whole designer just crash?
