Error Updating Gateway User Roles
Hi team,
I'm currently encountering an issue while updating user roles on the Ignition Gateway. This error occurs during the update process of gateway user roles, especially when handling a large number of records.
The system throws the following error message:
#### -ERROR [SS 254341.ClusterSession]_Transaction has unflushed updated records. This is normally caused by an unrelated Exception throwing to the finally block in which case ignore this message. But if no other exception then a commit() probably missing.
Thanks in advance
Sounds like a bug that should be reported to IA. (To IA support--this forum is not support.)
Thank you for the reply. I will reach out to Inductive Automation support to report this issue.
