Error updting DB with onCellEdited script at PowerTable
Hi everyone, I´ve been having issues with this code:
It won’t let me update any cell on my power table nor my DB when I try to edit it.
I did everything based on the information that I found here:
https://docs.inductiveautomation.com/display/DOC79/Updating+the+Database+through+the+Power+Table#UpdatingtheDatabasethroughthePowerTable-UsingaPowerTableComponent
I am getting these errors:
Does anyone know how to fix it??
Thanks in advance!!
Mis-spelled datasource name?
Is that a typo on line 34?
You’re using “Igintion”, and maybe it should be “Ignition”.
system.db.runPrepUpdate(query, args, "Ignition")
No, that is the name of the DB. It was misspelled since it was named.
So “Igintion” is the actual name of the DB.
