I keep getting an error when uploading images to our ignition 8.0 project.
The gateway connection falls out and comes back and then i get this error.
This also happens when I try to save the project.
I’m sorry to hear about the issues you are having, I have a couple of questions:
With the images:
- Does this happen will all images or just some?
- What is the file size of the images you are uploading?
- What type of file are you uploading (svg, png, jpg, gif)?
- Can you provide an example image you are having issues with?
With the project:
- Does the failure only happen after an image upload fails?
- Is this a clean install or did you migrate an existing Gateway?
Thanks,
Garth
It happens with any image I try to upload.
A collegue of mine can upload the same images to the same project.
File types vary.
The failure also happes if I try save and publish.
It was a migration yes.
Sure sounds like a networking related issue specific to your computer.
I’m closing this due to inactivity. If you are still having issues, please feel free to open a new post.
