I am having problems using Database Providers and Database Driving Providers. When I try to create a tag, a folder or even a scan class inside a Database Provider y get the following error :
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Results for asynchronous rpc call were not received within the specified amount of time [60000 ms] for task ‘31817d50-2f63-4830-89db-7fc47c1713ab’
However if I create an internal provider for Realtime Tags I can create tags without any problem. The Database is well configured as I can write from the script playground into it (it’s in PostgreSQL). The OPC-UA and SQL Bridge Modules are also running. I’m using Igniton V 7.6.6 in Windows Embedded 7.
This is the error report:
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:313)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:283)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:244)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:795)
at com.inductiveautomation.ignition.client.sqltags.impl.db.DatasourceTagManager.addTags(DatasourceTagManager.java:330)
at com.inductiveautomation.ignition.client.sqltags.impl.ClientTagManagerImpl.addTags(ClientTagManagerImpl.java:339)
at com.inductiveautomation.ignition.designer.sqltags.action.NewTagFolderAction.actionPerformed(NewTagFolderAction.java:61)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.AbstractButton.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$200(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
Caused by: java.util.concurrent.TimeoutException: Results for asynchronous rpc call were not received within the specified amount of time [60000 ms] for task ‘31817d50-2f63-4830-89db-7fc47c1713ab’
at com.inductiveautomation.ignition.client.util.gui.progress.ClientProgressManager$RunningTask.waitForResult(ClientProgressManager.java:486)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:268)
… 44 more
Ignition v7.6.6 (b2014040112)
Java: Oracle Corporation 1.7.0_67
Thank you guys for your time
