I’m attempting to make a “record editing window”, where
- a record is a single-row dataset as root container’s dynamic property,
- each field is bound to the dataset using expressions such as “{Root Container.row}[0, ‘Password’]” for the “Text”-property,
- each field has propertyChange handler updating the dataset every time the “Text” property changes.
This works fine for normal text input, but password field gives the error below.
Also, with calendar field (a simple date input), if using “Date”-property, the above arrangement
causes a total Designer lock-up. Calendar works, if using “Text”-property.
THE ERROR:
java.lang.Exception: Error setting property to ‘secret password’ for binding on
UserEdit.Root Container.txtPassword.text
at com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.updateTarget(AbstractPropertyAdapter.java:260)
at com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.updateValue(AbstractPropertyAdapter.java:203)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.runExpression(ExpressionPropertyAdapter.java:57)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.childInteractionUpdated(ExpressionPropertyAdapter.java:42)
at com.inductiveautomation.factorypmi.application.binding.PropertyListenerDescriptor.propertyChange(PropertyListenerDescriptor.java:67)
at java.beans.PropertyChangeSupport.firePropertyChange(PropertyChangeSupport.java:339)
at java.beans.PropertyChangeSupport.firePropertyChange(PropertyChangeSupport.java:347)
at java.beans.PropertyChangeSupport.firePropertyChange(PropertyChangeSupport.java:276)
at java.awt.Component.firePropertyChange(Component.java:8132)
at com.inductiveautomation.vision.api.client.components.model.AbstractVisionPanel.fireDynChange(AbstractVisionPanel.java:128)
at com.inductiveautomation.factorypmi.application.binding.util.DynamicPropertyUtil.setPropertyValue(DynamicPropertyUtil.java:217)
at com.inductiveautomation.vision.api.client.components.model.AbstractVisionPanel.setPropertyValue(AbstractVisionPanel.java:112)
at com.inductiveautomation.factorypmi.application.script.PyComponentWrapper.setattr(PyComponentWrapper.java:68)
at org.python.pycode._pyx15.f$0(event:propertyChange:4)
at org.python.pycode._pyx15.call_function(event:propertyChange)
at org.python.core.PyTableCode.call(PyTableCode.java)
at org.python.core.PyCode.call(PyCode.java)
at org.python.core.Py.runCode(Py.java)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:391)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:139)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:247)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:55)
at $Proxy0.propertyChange(Unknown Source)
at com.inductiveautomation.factorypmi.application.components.PMIPasswordField.access$000(PMIPasswordField.java:37)
at com.inductiveautomation.factorypmi.application.components.PMIPasswordField$1.insertUpdate(PMIPasswordField.java:53)
at javax.swing.text.AbstractDocument.fireInsertUpdate(AbstractDocument.java:185)
at javax.swing.text.AbstractDocument.handleInsertString(AbstractDocument.java:734)
at javax.swing.text.AbstractDocument.insertString(AbstractDocument.java:693)
at javax.swing.text.PlainDocument.insertString(PlainDocument.java:114)
at javax.swing.text.AbstractDocument.replace(AbstractDocument.java:655)
at javax.swing.text.JTextComponent.setText(JTextComponent.java:1693)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.updateTarget(AbstractPropertyAdapter.java:253)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.startup(ExpressionPropertyAdapter.java:71)
at com.inductiveautomation.factorypmi.application.FPMIWindow.startupAdapters(FPMIWindow.java:316)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$DesigntimeWindowOpener.openWindow(WindowWorkspace.java:2414)
at com.inductiveautomation.factorypmi.application.FPMIApp.openWindow(FPMIApp.java:860)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities$5.run(NavUtilities.java:374)
at com.inductiveautomation.factorypmi.application.script.builtin.WindowUtilities.doGUIAction(WindowUtilities.java:525)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.openWindowImpl(NavUtilities.java:321)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.openWindow(NavUtilities.java:317)
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.call(ScriptManager.java:310)
at org.python.core.PyObject.call(PyObject.java)
at org.python.core.PyObject.invoke(PyObject.java)
at org.python.pycode._pyx5.f$0(event:mouseClicked:8)
at org.python.pycode._pyx5.call_function(event:mouseClicked)
at $Proxy1.mouseClicked(Unknown Source)
at com.inductiveautomation.factorypmi.application.components.util.EventDelegateDispatcher$MouseEventDispatcher.mouseClicked(EventDelegateDispatcher.java:97)
at java.awt.AWTEventMulticaster.mouseClicked(AWTEventMulticaster.java:253)
at java.awt.Component.processMouseEvent(Component.java:6270)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
at java.awt.Component.processEvent(Component.java:6032)
at java.awt.Container.processEvent(Container.java:2041)
at java.awt.Component.dispatchEventImpl(Component.java:4630)
at java.awt.Container.dispatchEventImpl(Container.java:2099)
at java.awt.Component.dispatchEvent(Component.java:4460)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4577)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4247)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168)
at java.awt.Container.dispatchEventImpl(Container.java:2085)
at java.awt.Window.dispatchEventImpl(Window.java:2478)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Caused by: java.lang.IllegalStateException: Attempt to mutate in notification
at javax.swing.text.AbstractDocument.writeLock(AbstractDocument.java:1323)
at javax.swing.text.AbstractDocument.replace(AbstractDocument.java:644)
… 88 more
