Error: UUID string too large
Had an interesting error today:
...java.lang.IllegalArgumentException: UUID string too large
I was able to figure out that the tried and true troubleshooting and debugging method of "system.perspective.print()" was causing this error. I was trying to print out my input parameters and they... were too large for the print function.
Commenting out my print command resolved my issue.
I suppose one will just need to print portions of a largish array.
The rest of the stacktrace on that error would be interesting, if you've got it. That's certainly not a failure mode I would expect from printing a large array.
You could also try self.print(something), which goes through a slightly different mechanism. You don't get to control the output location, but it defaults to the same as system.perspective.print.
script 16Feb2023 14:11:43 Error running action 'component.onActionPerformed' on Scanner/MoveScan@D/root/fcButtons/btnSubmit: Traceback (most recent call last): File "function:runAction", line 65, in runAction File "module:WMS", line 74, in Move at java.base/java.util.UUID.fromString(Unknown Source) at com.inductiveautomation.perspective.gateway.script.AbstractScriptingFunctions.getSession(AbstractScriptingFunctions.java:91) at com.inductiveautomation.perspective.gateway.script.AbstractScriptingFunctions.operateOnSession(AbstractScriptingFunctions.java:118) at com.inductiveautomation.perspective.gateway.script.AbstractScriptingFunctions.operateOnPage(AbstractScriptingFunctions.java:47) at com.inductiveautomation.perspective.gateway.script.PerspectiveScriptingFunctions.print(PerspectiveScriptingFunctions.java:704) at jdk.internal.reflect.GeneratedMethodAccessor97.invoke(Unknown Source) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.base/java.lang.reflect.Method.invoke(Unknown Source) java.lang.IllegalArgumentException: java.lang.IllegalArgumentException: UUID string too large
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last): File "", line 65, in runAction File "", line 74, in Move at java.base/java.util.UUID.fromString(Unknown Source) at com.inductiveautomation.perspective.gateway.script.AbstractScriptingFunctions.getSession(AbstractScriptingFunctions.java:91) at com.inductiveautomation.perspective.gateway.script.AbstractScriptingFunctions.operateOnSession(AbstractScriptingFunctions.java:118) at com.inductiveautomation.perspective.gateway.script.AbstractScriptingFunctions.operateOnPage(AbstractScriptingFunctions.java:47) at com.inductiveautomation.perspective.gateway.script.PerspectiveScriptingFunctions.print(PerspectiveScriptingFunctions.java:704) at jdk.internal.reflect.GeneratedMethodAccessor97.invoke(Unknown Source) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.base/java.lang.reflect.Method.invoke(Unknown Source) java.lang.IllegalArgumentException: java.lang.IllegalArgumentException: UUID string too large
at org.python.core.Py.JavaError(Py.java:547)
at org.python.core.Py.JavaError(Py.java:538)
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:192)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.call(ScriptManager.java:552)
at org.python.core.PyObject.call(PyObject.java:477)
at org.python.core.PyObject.call(PyObject.java:481)
at org.python.pycode._pyx79.Move$9(:92)
at org.python.pycode._pyx79.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.PyBaseCode.call(PyBaseCode.java:187)
at org.python.core.PyFunction.call(PyFunction.java:449)
at org.python.core.PyMethod.call(PyMethod.java:171)
at org.python.pycode._pyx78.runAction$1(:78)
at org.python.pycode._pyx78.call_function()
at org.python.core.PyBaseCode.call(PyBaseCode.java:306)
at org.python.core.PyFunction.function___call__(PyFunction.java:474)
at org.python.core.PyFunction.call(PyFunction.java:469)
at org.python.core.PyFunction.call(PyFunction.java:464)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:846)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:828)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runFunction(ProjectScriptLifecycle.java:832)
at com.inductiveautomation.ignition.common.script.ScriptManager$ScriptFunctionImpl.invoke(ScriptManager.java:1009)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$AutoRecompilingScriptFunction.invoke(ProjectScriptLifecycle.java:897)
at com.inductiveautomation.perspective.gateway.script.ScriptFunctionHelper.invoke(ScriptFunctionHelper.java:147)
at com.inductiveautomation.perspective.gateway.action.ScriptAction.runAction(ScriptAction.java:74)
at com.inductiveautomation.perspective.gateway.model.ActionCollection$ActionSequence$ExecuteActionsTask.lambda$call$0(ActionCollection.java:263)
at com.inductiveautomation.perspective.gateway.api.LoggingContext.mdc(LoggingContext.java:54)
at com.inductiveautomation.perspective.gateway.model.ActionCollection$ActionSequence$ExecuteActionsTask.call(ActionCollection.java:252)
at com.inductiveautomation.perspective.gateway.model.ActionCollection$ActionSequence$ExecuteActionsTask.call(ActionCollection.java:221)
at com.inductiveautomation.perspective.gateway.threading.BlockingTaskQueue$TaskWrapper.run(BlockingTaskQueue.java:154)
at com.inductiveautomation.perspective.gateway.threading.BlockingWork$BlockingWorkRunnable.run(BlockingWork.java:58)
Caused by: org.python.core.PyException: java.lang.IllegalArgumentException: java.lang.IllegalArgumentException: UUID string too large
... 37 common frames omitted
Caused by: java.lang.IllegalArgumentException: UUID string too large
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:190)
... 34 common frames omitted
