Error when connecting Database connection using MSSQL
java.sql.SQLException: Cannot create PoolableConnectionFactory (Login failed for user ''. ClientConnectionId:bcfbdfb0-9ef8-477f-8b1a-0100475e5100)
at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:656)
at org.apache.commons.dbcp2.BasicDataSource.createDataSource(BasicDataSource.java:534)
at org.apache.commons.dbcp2.BasicDataSource.getConnection(BasicDataSource.java:734)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.getConnectionInternal(DatasourceImpl.java:300)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.runTest(DatasourceImpl.java:253)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl$FaultedDatasourceRetryer.lambda$newRetryRunnable$0(DatasourceManagerImpl.java:1096)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:587)
at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: Login failed for user ''. ClientConnectionId:bcfbdfb0-9ef8-477f-8b1a-0100475e5100
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:217)
at com.microsoft.sqlserver.jdbc.TDSTokenHandler.onEOF(tdsparser.java:251)
at com.microsoft.sqlserver.jdbc.TDSParser.parse(tdsparser.java:81)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.sendLogon(SQLServerConnection.java:3080)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.logon(SQLServerConnection.java:2361)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.access$100(SQLServerConnection.java:44)
at com.microsoft.sqlserver.jdbc.SQLServerConnection$LogonCommand.doExecute(SQLServerConnection.java:2347)
at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:6276)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:1794)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(SQLServerConnection.java:1405)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.login(SQLServerConnection.java:1069)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectInternal(SQLServerConnection.java:905)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:452)
at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:1014)
at org.apache.commons.dbcp2.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:52)
at org.apache.commons.dbcp2.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:357)
at org.apache.commons.dbcp2.BasicDataSource.validateConnectionFactory(BasicDataSource.java:103)
at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:652)
... 12 more
8.1.25 (b2023021409)
Azul Systems, Inc. 11.0.17
Q1. Have you set up an SQL user account for Ignition to use?
Q2. Are you using that account to log in?
Q3. Are you providing the correct password.
You can search for that error message on the Internet. Here's one answer:
Yes I setup SQL and login with window authentication, also enable TCP/IP
That might be your problem. Ignition may be trying to connect with a different user account.
I recommend creating an SQL user account with a password that never expires. Then set Ignition's database connection to use that.
Someone wiser may have better ideas.
You should tell us if the SQL server is on the gateway or on a different machine.
Thank you for information, now it is connected thanks again for information
You're welcome. Don't forget to mark one of the answers as the solution.
