I recently upgrade from 7.5 to 7.6 on a test server. When I click on On-Call Roster from the Configure tab on the gateway I get an Internal Error.
Error from System Console:
[code]
Time Logger Message
[ERROR] 10:55:01 AM DefaultExceptionMapper Unexpected error occurred
org.apache.wicket.WicketRuntimeException: Error attaching this container for rendering: [WebMarkupContainer [Component id = table]]
Caused by: java.lang.RuntimeException: An error occurred while getting the model object for Component: [ListView [Component id = rows, page = com.inductiveautomation.ignition.gateway.web.pages.Config, path = 18:config-contents:table:rows.ListView, isVisible = true, isVersioned = true]]
Caused by: java.lang.NullPointerException: No known record for table name: ROSTER
more[/code]
What version is this - 7.6.0? I believe this has been fixed in the latest 7.6.1 release candidates. Can you try it out and let us know?
It was 7.6.0, running on Linux.
I tried 7.6.1-rc5. I did get a warning on the install.
Installing
0% ______________ 50% ______________ 100%
########################################Warning: Problem running post-install step. Installation may not complete correctly
Error running chown -R root /etc/ignition/. : chown: cannot access
`/etc/ignition/.': No such file or directory
Press [Enter] to continue :
Setup has finished installing Ignition on your computer.
Start Ignition now [Y/n]: Y
So I created the /etc/ignition directory and ran the installer again.
I am still getting an error when I go to create an On-Call Roster.
Do I need to remove ignition and do a clean install?
Time Logger Message
[ERROR] 8:23:57 AM DefaultExceptionMapper Unexpected error occurred
at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1692)
at org.apache.wicket.Component.onBeforeRender(Component.java:3830)
at org.apache.wicket.Component.internalBeforeRender(Component.java:922)
at org.apache.wicket.Component.beforeRender(Component.java:990)
at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1680)
at com.inductiveautomation.ignition.gateway.web.components.RecordActionTable.onBeforeRender(RecordActionTable.java:294)
at org.apache.wicket.Page.onBeforeRender(Page.java:802)
at com.inductiveautomation.ignition.gateway.web.pages.BasePage.onBeforeRender(BasePage.java:161)
at com.inductiveautomation.ignition.gateway.web.pages.AuthenticatedPage.onBeforeRender(AuthenticatedPage.java:90)
at org.apache.wicket.Component.internalPrepareForRender(Component.java:2204)
at org.apache.wicket.Page.internalPrepareForRender(Page.java:247)
at org.apache.wicket.Component.render(Component.java:2289)
at org.apache.wicket.Page.renderPage(Page.java:1021)
at org.apache.wicket.request.handler.render.WebPageRenderer.renderPage(WebPageRenderer.java:116)
at org.apache.wicket.request.handler.render.WebPageRenderer.respond(WebPageRenderer.java:244)
at org.apache.wicket.core.request.handler.RenderPageRequestHandler.respond(RenderPageRequestHandler.java:165)
at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:814)
at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:253)
at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:210)
at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:281)
at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:188)
at org.apache.wicket.protocol.http.WicketFilter.doFilter(WicketFilter.java:245)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:861)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:606)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.RuntimeException: An error occurred while getting the model object for Component: [ListView [Component id = rows, page = com.inductiveautomation.ignition.gateway.web.pages.Config, path = 14:config-contents:table:rows.ListView, isVisible = true, isVersioned = true]]
at org.apache.wicket.Component.getDefaultModelObject(Component.java:1620)
at org.apache.wicket.markup.html.list.ListView.getViewSize(ListView.java:219)
at org.apache.wicket.markup.html.list.ListView.onPopulate(ListView.java:473)
at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:116)
... 41 more
at com.inductiveautomation.ignition.gateway.localdb.LocalDBManagerImpl.findRecordMeta(LocalDBManagerImpl.java:287)
at com.inductiveautomation.ignition.gateway.web.models.RecordListModel.load(RecordListModel.java:37)
at com.inductiveautomation.ignition.gateway.web.models.RecordListModel.load(RecordListModel.java:25)
at org.apache.wicket.model.LoadableDetachableModel.getObject(LoadableDetachableModel.java:121)
at org.apache.wicket.Component.getDefaultModelObject(Component.java:1615)
... 47 more
Are you still having this issue on the latest release (7.6.2?)
