Error When I query number from Database
This is pretty much line by line out of the manual, so I’m missing something. Operation is when a button is clicked it runs the query to match the part number they typed into the numbox to the part list in the DB
[code]partNum = event.source.parent.getComponent(‘numPartNumber_In’).longValue
results = system.db.runScalarQuery("SELECT part_num FROM ifa_parts WHERE " + “part_num = ?”, [partNum])
event.source.parent.getComponent(‘Text Field’).text = results[/code]
[quote]Traceback (most recent call last):
File “event:actionPerformed”, line 3, in
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:362)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runScalarQuery(AbstractDBUtilities.java:356)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
java.lang.Exception: java.lang.Exception: Error executing system.db.runScalarQuery(SELECT part_num FROM ifa_parts WHERE part_num = ?, [5500004602L], )
at org.python.core.Py.JavaError(Py.java:495)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:428)
at org.python.core.PyObject.__call__(PyObject.java:404)
at org.python.core.PyObject.__call__(PyObject.java:408)
at org.python.pycode._pyx186.f$0(<event:actionPerformed>:5)
at org.python.pycode._pyx186.call_function(<event:actionPerformed>)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.Py.runCode(Py.java:1275)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:624)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:168)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:265)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:55)
at com.sun.proxy.$Proxy19.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
Caused by: java.lang.Exception: Error executing system.db.runScalarQuery(SELECT part_num FROM ifa_parts WHERE part_num = ?, [5500004602L], )
… 56 more
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Connection Error: Datasource “[5500004602L]” does not exist in this Gateway.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:328)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:302)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:259)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.runLimitQuery(GatewayInterface.java:719)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.runQuery(GatewayInterface.java:683)
at com.inductiveautomation.ignition.client.script.ClientDBUtilities._runQuery(ClientDBUtilities.java:185)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runScalarQuery(AbstractDBUtilities.java:349)
… 54 more
Caused by: java.sql.SQLException: Datasource “[5500004602L]” does not exist in this Gateway.
at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl.getConnection(DatasourceManagerImpl.java:121)
at com.inductiveautomation.ignition.gateway.script.GatewayDBUtilities.getConnection(GatewayDBUtilities.java:66)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.AbstractDBAction.invoke(AbstractDBAction.java:60)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:343)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:769)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:585)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1125)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1059)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:52)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
at org.eclipse.jetty.server.Server.handle(Server.java:497)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:311)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:248)
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:540)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:610)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:539)
at java.lang.Thread.run(null)
Ignition v7.7.4 (b2015033012)
Java: Oracle Corporation 1.8.0_51
[/quote]
Wrong SQL function.
Use this one: system.db.runScalarPrepQuery
Best,
try
results = system.db.runScalarQuery("SELECT part_num FROM ifa_parts WHERE part_num = %d" % partNum)
nmudge
I received this error when I changed the code to:
partNum = event.source.parent.getComponent('numPartNumber_In').longValue results = system.db.runScalarPrepQuery("SELECT part_num FROM ifa_parts WHERE " + "part_num = ?", [partNum]) #results = system.db.runScalarQuery("SELECT part_num FROM ifa_parts WHERE part_num = %d" % partNum) event.source.parent.getComponent('Text Field').text = results
Error:
[code]Traceback (most recent call last):
java.lang.Exception: java.lang.Exception: Error executing system.db.runScalarPrepQuery(SELECT part_num FROM ifa_parts WHERE part_num = ?, , [5500004602], )
caused by Exception: Error executing system.db.runScalarPrepQuery(SELECT part_num FROM ifa_parts WHERE part_num = ?, , [5500004602], )
caused by GatewayException: The conversion from UNKNOWN to UNKNOWN is unsupported.
caused by SQLServerException: The conversion from UNKNOWN to UNKNOWN is unsupported.
Java: Oracle Corporation 1.8.0_51[/code]
Tim,
I received this error when I changed the code to this:
partNum = event.source.parent.getComponent('numPartNumber_In').longValue #results = system.db.runScalarPrepQuery("SELECT part_num FROM ifa_parts WHERE " + "part_num = ?", [partNum]) results = system.db.runScalarQuery("SELECT part_num FROM ifa_parts WHERE part_num = %d" % partNum) event.source.parent.getComponent('Text Field').text = results
Error:
File “event:actionPerformed”, line 4, in
TypeError: can’t convert 5500004602L to java.lang.String
[/code]
Does anyone know what it’s adding the “L” to the end of the number?
[quote=“jreynolds”]Does anyone know what it’s adding the “L” to the end of the number?[/quote]Because it is a long integer. In Python long integer literals have an L at the end of them to differentiate them from integers.
It just means you have to coerce the long integer before sending it to the text field:
event.source.parent.getComponent('Text Field').text = str(results)
Thanks, for your help. Coercing it to a string solved the error.
Hello, I am having a similar issue with querying in a tag event script. When running the below line in a button action performed script I have no issues, but when the same query is placed into the tag event script or gateway script I receive the below errors. I’ve attempted several query types including basic runQuery and prep queries, but none of those have worked either. I appreciate any help with this thanks.
Script trying to run:
ID = system.db.runScalarQuery(“SELECT TOP 1 ID FROM [HX_OEE].[dbo].[LWGT_Load_Times_Temp]”)
Error executing script.
File “tagevent:valueChanged”, line 4, in valueChanged
at sun.reflect.GeneratedMethodAccessor572.invoke(Unknown Source)
java.lang.Exception: java.lang.Exception: Error executing system.db.runScalarQuery(SELECT TOP 1 ID FROM [HX_OEE].[dbo].[LWGT_Load_Times_Temp], , )
In the gateway scope you need to supply the datasource name, in the project scope it will default to the projects default datasource.
system.db.runScalarQuery(“SELECT TOP 1 ID FROM LWGT_Load_Times_Temp ORDER BY ID DESC”, 'HX_OEE')
Awesome that worked thank you! I have a follow up question now though.
In another server I usually format my gateway event script queries in the way I originally listed with the database inside the query string, and they have worked with that syntax. That server is on v7.9.10 while this one I had an issue with is on v7.9.12. Would there be any differences in these minor revs that could affect syntax for the queries?
Oh please ignore what I just commented, I forgot gateway events are still listed under project scripts I understand. Thanks again.
