Recently, our server crashed that we had the Inductive Automation software on. So during the resurection period we upgraded to 4.1.5.
While doing the reinstall a few things came up that I wanted to question you on.
I have about 8 CSV files for SQL tags. I had saved each individually and the all as a group, this way if only one section needs updated or adjusted it makes it easier. While re-importing them back into FPMI I received the error message at the bottom of this post from 3 out of the 8 csv files. What does the error message mean?
Are the SQL tags saved/backed up during a project back up in FPMI? I know that last week I did a backup but when I restored that file there was no SQL tags which is why I had to re-import them in item 1 above.
As mentioned to Colby on Friday of last week the witness server saw some sort of problem with the server running the inductive automation software. When the IT dept did as requested, which was a reboot of the server, when they were trying to bring it back up, everything was lost. So in reference to this question I was wondering:
a: How does one get their activation reset? What about holiday time?
b: How much does it cost to get the Donlge? (hardware key)
Thanks and have a great day.
java.lang.NullPointerException: Null child not allowed
at javax.swing.tree.TreePath.pathByAddingChild(Unknown Source)
at javax.swing.tree.VariableHeightLayoutCache$TreeStateNode.setParent(Unknown Source)
at javax.swing.tree.DefaultMutableTreeNode.insert(Unknown Source)
at javax.swing.tree.VariableHeightLayoutCache.createNodeAt(Unknown Source)
at javax.swing.tree.VariableHeightLayoutCache.treeStructureChanged(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI$Handler.treeStructureChanged(Unknown Source)
at javax.swing.tree.DefaultTreeModel.fireTreeStructureChanged(Unknown Source)
at javax.swing.tree.DefaultTreeModel.nodeStructureChanged(Unknown Source)
at com.calmetrics.factoryhmi.designer.sqltags.tree.AbstractTagPathTreeNode.loadDone(AbstractTagPathTreeNode.java:126)
at com.calmetrics.factoryhmi.designer.sqltags.tree.AbstractTagPathTreeNode$Loader$1.run(AbstractTagPathTreeNode.java:70)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
