Error when opening Ignition perspective
Hello, I’m having an error when opening Ignition perspective. I was trying to export a project from one designer and import it into another, but when it doesn’t properly copy over the views or the named queries. In fact, the views folder is missing entirely from perspective. Please see the logs below.
20:37:25.924 [Designer-Startup] INFO designer.main - Downloading… [+0]
20:37:26.131 [Designer-Startup] INFO designer.main - Cleanup… [+207]
20:37:26.135 [Designer-Startup] INFO designer.main - Initializing UI… [+211]
20:37:26.184 [Designer-Startup] INFO tags.manager.gwinterface - Tag poll rate changed to 250 ms
20:37:26.184 [DesignerExecEngine-1] INFO tags.subscriptions - Changing connected quality to ‘Good’
20:37:27.626 [Designer-Startup] INFO designer.main - Starting module: Vision [+1702]
20:37:27.791 [Designer-Startup] ERROR Scripting.ScriptManager.CZWL_LocalDev - Warning: collision at system.util.modifyTranslation
20:37:27.791 [Designer-Startup] ERROR Scripting.ScriptManager.CZWL_LocalDev - Warning: collision at system.util.translate
20:37:27.791 [Designer-Startup] ERROR Scripting.ScriptManager.CZWL_LocalDev - Warning: collision at system.util.initialize
20:37:29.669 [Designer-Startup] INFO designer.main - Starting module: Perspective [+3745]
20:37:31.121 [Designer-Startup] INFO Perspective.Designer - Starting up Perspective module. Mode: Trial
20:37:32.054 [AWT-EventQueue-0] INFO Perspective.SessionProps - Session props debug url: http://localhost:9222/devtools/inspector.html?ws=localhost:9222/devtools/page/9ADBCFEA913686BC4759D28EA272B896
20:37:32.302 [Designer-Startup] ERROR designer.main - Error starting up module Perspective
java.lang.NullPointerException: null
at java.base/java.util.Objects.requireNonNull(Unknown Source)
at java.base/java.util.stream.Collectors.lambda$uniqKeysMapAccumulator$1(Unknown Source)
at java.base/java.util.stream.ReduceOps$3ReducingSink.accept(Unknown Source)
at java.base/java.util.ArrayList$ArrayListSpliterator.forEachRemaining(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.copyInto(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
at java.base/java.util.stream.ReduceOps$ReduceOp.evaluateSequential(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.evaluate(Unknown Source)
at java.base/java.util.stream.ReferencePipeline.collect(Unknown Source)
at com.inductiveautomation.perspective.designer.DesignerHook$NamedQueryListener.sendInitial(DesignerHook.java:623)
at com.inductiveautomation.perspective.designer.DesignerHook.lambda$startup$2(DesignerHook.java:243)
at java.base/java.util.Optional.ifPresent(Unknown Source)
at com.inductiveautomation.perspective.designer.DesignerHook.startup(DesignerHook.java:203)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$LoadedModule.startup(IgnitionDesigner.java:1934)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.startupModule(IgnitionDesigner.java:1174)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.lambda$loadProject$7(IgnitionDesigner.java:976)
at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.accept(Unknown Source)
at java.base/java.util.stream.ReferencePipeline$2$1.accept(Unknown Source)
at java.base/java.util.stream.ForEachOps$ForEachOp.evaluateSequential(Unknown Source)
at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(Unknown Source)
at java.base/java.util.stream.ReferencePipeline.forEach(Unknown Source)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.loadProject(IgnitionDesigner.java:975)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$StartupProjectDialogHandler.lambda$new$2(IgnitionDesigner.java:1998)
20:37:32.385 [Designer-Startup] INFO designer.main - Starting module: Symbol Factory [+6461]
20:37:32.389 [Designer-Startup] INFO designer.main - Starting module: Alarm Notification [+6465]
20:37:32.489 [Designer-Startup] INFO designer.main - Starting module: SFC [+6565]
20:37:32.952 [Designer-Startup] INFO designer.main - Starting module: OPC-UA [+7028]
20:37:32.953 [Designer-Startup] INFO designer.main - Starting module: Enterprise Administration [+7029]
20:37:32.960 [Designer-Startup] INFO designer.main - Starting module: SQL Bridge [+7036]
20:37:33.121 [Designer-Startup] INFO designer.main - Starting module: DNP3 Driver [+7197]
20:37:33.121 [Designer-Startup] INFO designer.main - Starting module: Serial Support Client [+7197]
20:37:33.123 [Designer-Startup] INFO designer.main - Starting module: OpcCom [+7199]
20:37:33.124 [Designer-Startup] INFO designer.main - Starting module: Reporting [+7200]
20:37:33.146 [Designer-Startup] INFO reporting.Designer - Starting up Reporting Module. Mode: Trial
20:37:33.402 [Designer-Startup] INFO designer.main - Initializing Scripting… [+7478]
20:37:33.447 [Designer-Startup] INFO designer.main - Initializing UI… [+7523]
Exception in thread “AWT-EventQueue-0” java.lang.NullPointerException
at com.inductiveautomation.perspective.designer.workspace.ViewWorkspace.getNavTreeNodeParent(ViewWorkspace.java:279)
at com.inductiveautomation.ignition.designer.tabbedworkspace.TabbedResourceWorkspace.registerNavTreeNode(TabbedResourceWorkspace.java:206)
at com.inductiveautomation.ignition.designer.tabbedworkspace.TabbedResourceWorkspace.lambda$new$0(TabbedResourceWorkspace.java:125)
20:37:35.139 [Browser Thread: 55658] INFO Perspective.SessionProps - [mobx] Encountered an uncaught exception that was thrown by a reaction or observer component, in: ‘Reaction[When@56]’ java.lang.NullPointerException in com.inductiveautomation.perspective.designer.workspace.JavaJsBridge.getStyles(JavaJsBridge.java:742)
Oct. 29, 2021 8:37:35 P.M. com.google.common.eventbus.EventBus$LoggingHandler handleException
SEVERE: Exception thrown by subscriber method onSelectionChange(com.inductiveautomation.perspective.designer.workspace.events.SelectionChangeEvent) on subscriber com.inductiveautomation.perspective.designer.workspace.propertyeditor.PropertyEditorFrame[key=PerspectivePropEditor,title=Perspective Property Editor,mode=DOCK,side=EAST] when dispatching event: com.inductiveautomation.perspective.designer.workspace.events.SelectionChangeEvent@d957c10
at com.inductiveautomation.perspective.designer.workspace.ComponentSelection.getDesignDelegate(ComponentSelection.java:348)
at com.inductiveautomation.perspective.designer.workspace.propertyeditor.ComponentPropsDocumentModel.(ComponentPropsDocumentModel.java:85)
at com.inductiveautomation.perspective.designer.workspace.propertyeditor.ComponentScopeEditor.onSelectionChanged(ComponentScopeEditor.java:165)
at com.inductiveautomation.perspective.designer.workspace.propertyeditor.PropertyEditorFrame.setSelection(PropertyEditorFrame.java:462)
at com.inductiveautomation.perspective.designer.workspace.propertyeditor.PropertyEditorFrame.onSelectionChange(PropertyEditorFrame.java:309)
at com.google.common.eventbus.Subscriber.invokeSubscriberMethod(Subscriber.java:91)
at com.google.common.eventbus.Subscriber$SynchronizedSubscriber.invokeSubscriberMethod(Subscriber.java:150)
at com.google.common.eventbus.Subscriber$1.run(Subscriber.java:76)
at com.google.common.util.concurrent.MoreExecutors$DirectExecutor.execute(MoreExecutors.java:399)
at com.google.common.eventbus.Subscriber.dispatchEvent(Subscriber.java:71)
at com.google.common.eventbus.Dispatcher$PerThreadQueuedDispatcher.dispatch(Dispatcher.java:116)
at com.google.common.eventbus.EventBus.post(EventBus.java:217)
at com.inductiveautomation.perspective.designer.workspace.pageconfig.SessionPropsAdapter.updateSelection(SessionPropsAdapter.java:270)
at com.inductiveautomation.perspective.designer.workspace.pageconfig.SessionPropsAdapter$SessionAdapterBridge.lambda$onSelectionChangeInternal$0(SessionPropsAdapter.java:341)
20:37:35.195 [AWT-EventQueue-0] ERROR perspective.PropertyEditorFrame - Uncaught error handling property update.
java.lang.ClassCastException: class com.inductiveautomation.ignition.client.jsonedit.DocumentModel cannot be cast to class com.inductiveautomation.perspective.designer.workspace.propertyeditor.ComponentPropsDocumentModel (com.inductiveautomation.ignition.client.jsonedit.DocumentModel and com.inductiveautomation.perspective.designer.workspace.propertyeditor.ComponentPropsDocumentModel are in unnamed module of loader java.net.URLClassLoader @2cc962ca)
at com.inductiveautomation.perspective.designer.workspace.propertyeditor.ComponentScopeEditor.getPropsModel(ComponentScopeEditor.java:179)
at com.inductiveautomation.perspective.designer.workspace.propertyeditor.PropertyEditorFrame.onPropertiesUpdated(PropertyEditorFrame.java:437)
at com.inductiveautomation.perspective.designer.workspace.pageconfig.SessionPropsAdapter$SessionAdapterBridge.lambda$onSelectionPropertyChangeInternal$1(SessionPropsAdapter.java:346)
20:37:35.211 [AWT-EventQueue-0] ERROR perspective.PropertyEditorFrame - Uncaught error handling property update.
You should get in contact with support. Something is going critically wrong during designer startup; it’s hard to pinpoint exactly the root cause from the isolated stacktrace.
https://support.inductiveautomation.com/
