When I try to open an image folder in the explorer I receive this error in the console and the folder will not open.
[quote]Exception in thread “AWT-EventQueue-0” com.google.common.cache.CacheLoader$InvalidCacheLoadException: CacheLoader returned null for key java.awt.Dimension[width=62,height=62].
at com.google.common.cache.LocalCache$Segment.getAndRecordStats(LocalCache.java:2383)
at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2351)
at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2313)
at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2228)
at com.google.common.cache.LocalCache.get(LocalCache.java:3965)
at com.google.common.cache.LocalCache.getOrLoad(LocalCache.java:3969)
at com.google.common.cache.LocalCache$LocalManualCache.get(LocalCache.java:4829)
at com.inductiveautomation.ignition.client.images.ImageLoader$ImageInfo.getScaledImage(ImageLoader.java:510)
at com.inductiveautomation.ignition.client.images.ImageLoader.loadImageMemCache(ImageLoader.java:163)
at com.inductiveautomation.ignition.client.images.ImageLoader.loadImage(ImageLoader.java:138)
at com.inductiveautomation.ignition.client.images.PathIcon.setPath(PathIcon.java:328)
at com.inductiveautomation.ignition.client.images.PathIcon.setStretchSize(PathIcon.java:287)
at com.inductiveautomation.ignition.designer.gui.ImageThumbnail.reloadImage(ImageThumbnail.java:156)
at com.inductiveautomation.ignition.designer.gui.ImageThumbnail.setPreferredSize(ImageThumbnail.java:58)
at com.inductiveautomation.ignition.designer.gui.ImageThumbnail.(ImageThumbnail.java:49)
at com.inductiveautomation.ignition.designer.gui.tools.ImageBrowser$ThumbnailPanel.createThumbnail(ImageBrowser.java:831)
at com.inductiveautomation.ignition.designer.gui.tools.ImageBrowser$ThumbnailPanel.setFolder(ImageBrowser.java:871)
at com.inductiveautomation.ignition.designer.gui.tools.ImageBrowser.setFolder(ImageBrowser.java:782)
at com.inductiveautomation.ignition.designer.gui.tools.ImageBrowser.pathChosen(ImageBrowser.java:1302)
at com.inductiveautomation.ignition.designer.gui.tools.ImageBrowser.propertyChange(ImageBrowser.java:1295)
at java.beans.PropertyChangeSupport.fire(Unknown Source)
at java.beans.PropertyChangeSupport.firePropertyChange(Unknown Source)
at java.awt.Component.firePropertyChange(Unknown Source)
at com.inductiveautomation.ignition.designer.gui.tools.ImageBrowser$ThumbnailPanel.access$200(ImageBrowser.java:807)
at com.inductiveautomation.ignition.designer.gui.tools.ImageBrowser$ThumbnailPanel$ClickListener.mouseClicked(ImageBrowser.java:1034)
at java.awt.AWTEventMulticaster.mouseClicked(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$200(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
at java.awt.WaitDispatchSupport$2.run(Unknown Source)
at java.awt.WaitDispatchSupport$4.run(Unknown Source)
at java.awt.WaitDispatchSupport.enter(Unknown Source)
at java.awt.Dialog.show(Unknown Source)
at java.awt.Component.show(Unknown Source)
at java.awt.Component.setVisible(Unknown Source)
at java.awt.Window.setVisible(Unknown Source)
at java.awt.Dialog.setVisible(Unknown Source)
at com.inductiveautomation.ignition.designer.gui.tools.ImageChooser.choosePath(ImageChooser.java:55)
at com.inductiveautomation.factorypmi.designer.projectproperties.ImageChooserField.chooseImage(ImageChooserField.java:90)
at com.inductiveautomation.factorypmi.designer.projectproperties.ImageChooserField.access$000(ImageChooserField.java:26)
at com.inductiveautomation.factorypmi.designer.projectproperties.ImageChooserField$1.actionPerformed(ImageChooserField.java:42)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
[/quote]
