Error when opening page with Box and Whisker Chart
Every time I attempt to open this page the first time that has a box and whisker chart on it, I get the following error that I cannot figure out (works fine every time after the first attempt):
com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error invoking [PMIBoxWhiskerChart]com.inductiveautomation.factorypmi.application.components.PMIBoxWhiskerChart[Box and Whisker Chart,25,106,1600x720,invalid,layout=java.awt.FlowLayout,alignmentX=0.0,alignmentY=0.0,border=javax.swing.plaf.synth.SynthBorder@494236ef,flags=9,maximumSize=,minimumSize=,preferredSize=java.awt.Dimension[width=321,height=295]].setSeriesColors([Ljava.awt.Color;@501033a5)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.handlers.ObjectDeserializationHandler.endSubElement(ObjectDeserializationHandler.java:82)
at com.inductiveautomation.factorypmi.application.xmlserialization.ComponentDeserializationHandler.endSubElement(ComponentDeserializationHandler.java:102)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$ParseContext.onElementEnd(XMLDeserializer.java:923)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:165)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:157)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.parse(BinaryParser.java:51)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserializeBinary(XMLDeserializer.java:358)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:268)
at com.inductiveautomation.factorypmi.application.model.WindowCache._deserializeWindow(WindowCache.java:381)
at com.inductiveautomation.factorypmi.application.model.WindowCache._loadWindow(WindowCache.java:324)
at com.inductiveautomation.factorypmi.application.model.WindowCache.openWindow(WindowCache.java:298)
at com.inductiveautomation.factorypmi.application.VisionDesktop$RuntimeWindowOpener.openWindow(VisionDesktop.java:489)
at com.inductiveautomation.factorypmi.application.VisionDesktop.openWindow(VisionDesktop.java:192)
at com.inductiveautomation.factorypmi.application.script.builtin.SecurityUtilities._tempReOpen(SecurityUtilities.java:178)
at com.inductiveautomation.factorypmi.application.script.builtin.SecurityUtilities._tempReOpen(SecurityUtilities.java:157)
at com.inductiveautomation.factorypmi.application.runtime.UpdateProjectPane.uninstall(UpdateProjectPane.java:80)
at com.inductiveautomation.factorypmi.application.runtime.UpdateProjectPane$1.stepsFinished(UpdateProjectPane.java:69)
Caused by: java.lang.reflect.InvocationTargetException
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.handlers.ObjectDeserializationHandler.endSubElement(ObjectDeserializationHandler.java:69)
... 38 more
Caused by: java.lang.IllegalArgumentException: Range(double, double): require lower (Infinity) <= upper (-Infinity).
at org.jfree.data.Range.(Range.java:90)
at org.jfree.data.statistics.DefaultBoxAndWhiskerCategoryDataset.getRangeBounds(DefaultBoxAndWhiskerCategoryDataset.java:634)
at org.jfree.data.general.DatasetUtilities.findRangeBounds(DatasetUtilities.java:742)
at org.jfree.data.general.DatasetUtilities.findRangeBounds(DatasetUtilities.java:722)
at org.jfree.chart.renderer.category.AbstractCategoryItemRenderer.findRangeBounds(AbstractCategoryItemRenderer.java:675)
at org.jfree.chart.plot.CategoryPlot.getDataRange(CategoryPlot.java:3806)
at org.jfree.chart.axis.NumberAxis.autoAdjustRange(NumberAxis.java:426)
at org.jfree.chart.axis.NumberAxis.configure(NumberAxis.java:409)
at org.jfree.chart.axis.Axis.setPlot(Axis.java:838)
at org.jfree.chart.plot.CategoryPlot.(CategoryPlot.java:535)
at com.inductiveautomation.factorypmi.application.components.PMIBoxWhiskerChart.createBoxWhiskerChart(PMIBoxWhiskerChart.java:264)
at com.inductiveautomation.factorypmi.application.components.PMIBoxWhiskerChart.updateChart(PMIBoxWhiskerChart.java:107)
at com.inductiveautomation.factorypmi.application.components.PMIBoxWhiskerChart.setSeriesColors(PMIBoxWhiskerChart.java:371)
... 43 more
Ignition v8.1.19 (b2022072711)
Java: Azul Systems, Inc. 11.0.15
How is your data being populated? It looks like the lower bound of your range axis is somehow exceeding the upper bound.
Thanks for the quick response. I couldn't figure it out because the data was being pulled from a query that was perfectly fine. I deleted everything and remade it the exact same way and that fixed the issue somehow. Maybe I had a small error somewhere or it was just stuck in error somehow.
