The first time I right click on a Client SQLTag and select ‘Edit Tag(s)’, I get the following error:Exception in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: Illegal Constraint: '1'
Unknown keyword.
at net.miginfocom.layout.ConstraintParser.parseComponentConstraint(Unknown Source)
at net.miginfocom.swing.MigLayout.setComponentConstraintsImpl(Unknown Source)
at net.miginfocom.swing.MigLayout.addLayoutComponent(Unknown Source)
at java.awt.Container.addImpl(Unknown Source)
at java.awt.Container.add(Unknown Source)
at com.inductiveautomation.ignition.designer.sqltags.editor.ExpressionCategory$SQLEditor.init(ExpressionCategory.java:417)
at com.inductiveautomation.ignition.designer.sqltags.editor.ExpressionCategory.init(ExpressionCategory.java:171)
at com.inductiveautomation.ignition.designer.sqltags.editor.TagEditorPanel.editTags(TagEditorPanel.java:212)
at com.inductiveautomation.ignition.designer.sqltags.action.EditTagAction$1.run(EditTagAction.java:52)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
I can then view other Client tag properties without error until I view the properties of a DB tag. The next time I try to display the properties of a Client tag, I get the error again.
I am using Ignition v7.1.0 (b5058) on Windows XP Pro with Java 1.6.0_20.
