Hi community, I'm a beginner in ignition, I'm trying to write in the reference to a file in my tag, but it sends me the following message.
Technical Problem - Parameters in the DB configuration are either missing or wrong - Image Filename - Missing tags
Welcome to the forum, Roberto.
Your question is unusual.
- Why would you store a filename in a tag?
- How is this related to the database (if that's what DB is)?
Thanks Transistor , I process .csv files and needs insert the name of the file in DB (SQL Server), I watch this propierty in my tag, but when I try save the information, check the tag and watch this message.
Thanks for your answer Transistor, I get a machine, this machine make a .csv files with production information, I read this diles and put the data in SQL Server Data Base, I wanna get a historial about the files in Ignition, I wanna use ImageFilename tag in the UDT, but get this error and don't watch the file my database.
