Hello,
I am new to ignition.. While installing Designer on my Windows 11 system I get an error as attached.
What could be causing this?
Windows can't find your destination folder path.
A few steps before this the install program asked where Ignition should be installed.
You either selected an installation path that does not exist, or you do not have permissions to install Ignition in this location.
Yes, I meant exactly that, but you did a better job.
It did not give me the option to select a path... I tried it on other system and it worked.. However it is not working on the system where i want to use the designer
Delete the cache, do an uninstall from the Control Panel, and then reinstall. Something was likely holding onto the old path
