Error with custom method call from context menu
I have a button component to perform different actions using the context menu, but have encountered a problem with calling custom methods on the same component. Editor version is 8.1.25 (b2023021409)
To open the menu on the button, I use the following option:
requestMenu
Then I want to call "customMethod" without any parameters from one of the context menu options (also on the button). I also tried with "self.customMethod" in the name property:
contextmenu
The method "customMethod" is defined on the button:
customMethod
On the gateway logger I get the following error:
Alternatively, we could use messages for the same functionality and that works as intended. Does anybody know why the method approach does not work?
Start here, but read the whole topic:
TL/DR: Install my free Simulation Aids module to get reliable jython behavior with components no matter what java methods delivered them.
This is a known bug, I think right now the fix will be in 8.1.27.
I installed 8.1.27 today and it looks like they did fix this bug.
