hello everyone
I have a Query Tag Type string, and I need used in Dropdown List, but I have the next error
Please limit your post tags to the platform you are using.
In your tag browser, I see a value, and not something that says it’s a dataset. I’m guessing your tag is set as a string.
Yes, it’s a TAG query of type STRING
Yes, but you’re trying to bind it to a dataset. That is not going to work. Try changing the tag datatype to dataset.
that’s it, thank you very much now just a question how can I read it?
I am doing it in the following way but it gives me an error
Type = system.tag.read (“Type_Stop”). Value.getValueAt (0, ‘Type’)
Do you mean from the dropdown? Use the selectedLabel property
I want to save the selected data from the list
I have the following error
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last): File “”, line 19, in valueChanged at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:362) at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:258) at sun.reflect.GeneratedMethodAccessor55.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(INSERT INTO PAROS (Linea, Maquina, TipoParo, TiempoParo, Fecha) VALUES (?, ?, ?, ?, ?), [Disco, Disco, Dataset [11R ? 2C], 00:01:00, Wed Apr 28 13:24:02 CDT 2021], TOPY_MW, , false, false)
at org.python.core.Py.JavaError(Py.java:495)
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:186)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.call(ScriptManager.java:431)
at org.python.core.PyObject.call(PyObject.java:422)
at org.python.core.PyObject.call(PyObject.java:426)
at org.python.pycode._pyx8490768.valueChanged$1(:19)
at org.python.pycode._pyx8490768.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.PyBaseCode.call(PyBaseCode.java:301)
at org.python.core.PyFunction.function___call__(PyFunction.java:376)
at org.python.core.PyFunction.call(PyFunction.java:371)
at org.python.core.PyFunction.call(PyFunction.java:361)
at org.python.core.PyFunction.call(PyFunction.java:356)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:649)
at com.inductiveautomation.ignition.common.sqltags.scripts.TagScriptManager$FunctionInvokerImpl.run(TagScriptManager.java:493)
at com.inductiveautomation.ignition.common.sqltags.scripts.AbstractTagScript.invoke(AbstractTagScript.java:33)
at com.inductiveautomation.ignition.common.sqltags.scripts.TagScriptManager$Task.invoke(TagScriptManager.java:442)
at com.inductiveautomation.ignition.common.sqltags.scripts.TagScriptManager$TagScriptDispatcher.run(TagScriptManager.java:405)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:518)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: org.python.core.PyException: Traceback (most recent call last): File “”, line 19, in valueChanged at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:362) at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:258) at sun.reflect.GeneratedMethodAccessor55.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(INSERT INTO PAROS (Linea, Maquina, TipoParo, TiempoParo, Fecha) VALUES (?, ?, ?, ?, ?), [Disco, Disco, Dataset [11R ? 2C], 00:01:00, Wed Apr 28 13:24:02 CDT 2021], TOPY_MW, , false, false)
… 31 common frames omitted
Caused by: java.lang.Exception: Error executing system.db.runPrepUpdate(INSERT INTO PAROS (Linea, Maquina, TipoParo, TiempoParo, Fecha) VALUES (?, ?, ?, ?, ?), [Disco, Disco, Dataset [11R ⅹ 2C], 00:01:00, Wed Apr 28 13:24:02 CDT 2021], TOPY_MW, , false, false)
… 30 common frames omitted
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The conversion from UNKNOWN to UNKNOWN is unsupported.
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDriverError(SQLServerException.java:170)
at com.microsoft.sqlserver.jdbc.DataTypes.throwConversionError(DataTypes.java:946)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.setObject(SQLServerPreparedStatement.java:958)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.setObjectNoType(SQLServerPreparedStatement.java:910)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.setObject(SQLServerPreparedStatement.java:919)
at org.apache.commons.dbcp.DelegatingPreparedStatement.setObject(DelegatingPreparedStatement.java:166)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRPreparedStatement.setObject(SRConnectionWrapper.java:1055)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper.runPrepUpdate(SRConnectionWrapper.java:178)
at com.inductiveautomation.ignition.gateway.script.GatewayDBUtilities._runPrepStmt(GatewayDBUtilities.java:132)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:256)
… 28 common frames omitted
You can't supply a Dataset as a parameter, SQL doesn't understand what to do with it.
You'll need to loop through the selected items and run an update for each row.
I think we need to back up a bit and detail what you are trying to do.
I want to save the selected information from the Dropdown List
in the database
I already made it, thank you very much.
I removed them all from his other post ![]()
