Error with system.db.runUpdateQuery
Hi, I'm trying to insert data into sql db on tag value changed and I'm getting this error.
("TAGPATH", valueChanged) Error executing tag event script: Traceback (most recent call last): File "tagevent:valueChanged", line 20, in valueChanged at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:392) at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runUpdateQuery(AbstractDBUtilities.java:188) at jdk.internal.reflect.GeneratedMethodAccessor205.invoke(Unknown Source) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.base/java.lang.reflect.Method.invoke(Unknown Source) java.lang.Exception: java.lang.Exception: Error executing system.db.runUpdateQuery(INSERT INTO group_table (ShiftStart, ShiftEnd, ShiftNo, Takt, ScheduledUnit, Target, Completed, DraggingUnit, WorkingDate, t_stamp)VALUES ('Fri Aug 18 06:00:00 CDT 2023','Fri Aug 18 17:00:00 CDT 2023','1','129','220','220','None','0','Fri Aug 18 09:17:03 CDT 2023','Fri Aug 18 09:17:03 CDT 2023'), "DATABASE", , false)
What does this error mean?
Are you sure that's the entire error you're getting?
Here is the rest of it.
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last): File "", line 22, in valueChanged at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:392) at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runUpdateQuery(AbstractDBUtilities.java:188) at jdk.internal.reflect.GeneratedMethodAccessor205.invoke(Unknown Source) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.base/java.lang.reflect.Method.invoke(Unknown Source) java.lang.Exception: java.lang.Exception: Error executing system.db.runUpdateQuery(INSERT INTO group_table (ShiftStart, ShiftEnd, ShiftNo, Takt, ScheduledUnit, Target, Completed, DraggingUnit, WorkingDate, t_stamp)VALUES ('Fri Aug 18 06:00:00 CDT 2023','Fri Aug 18 17:00:00 CDT 2023','1','129','200','200','0','0','Fri Aug 18 10:05:04 CDT 2023','Fri Aug 18 10:05:05 CDT 2023'), VersaCall_LKC, , false)
at org.python.core.Py.JavaError(Py.java:547)
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:190)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.call(ScriptManager.java:552)
at org.python.core.PyObject.call(PyObject.java:477)
at org.python.core.PyObject.call(PyObject.java:481)
at org.python.pycode._pyx31.valueChanged$1(:22)
at org.python.pycode._pyx31.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.PyBaseCode.call(PyBaseCode.java:306)
at org.python.core.PyFunction.function___call__(PyFunction.java:474)
at org.python.core.PyFunction.call(PyFunction.java:469)
at org.python.core.PyFunction.call(PyFunction.java:464)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:846)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:828)
at com.inductiveautomation.ignition.gateway.tags.scripting.TagScriptManagerImpl$FunctionInvokerImpl.run(TagScriptManagerImpl.java:533)
at com.inductiveautomation.ignition.gateway.tags.scripting.events.AbstractTagScript.invoke(AbstractTagScript.java:34)
at com.inductiveautomation.ignition.gateway.tags.scripting.TagScriptManagerImpl$Task.invoke(TagScriptManagerImpl.java:482)
at com.inductiveautomation.ignition.gateway.tags.scripting.TagScriptManagerImpl$TagScriptDispatcher.run(TagScriptManagerImpl.java:445)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:544)
Caused by: org.python.core.PyException: java.lang.Exception: java.lang.Exception: Error executing system.db.runUpdateQuery(INSERT INTO group_table (ShiftStart, ShiftEnd, ShiftNo, Takt, ScheduledUnit, Target, Completed, DraggingUnit, WorkingDate, t_stamp)VALUES ('Fri Aug 18 06:00:00 CDT 2023','Fri Aug 18 17:00:00 CDT 2023','1','129','200','200','0','0','Fri Aug 18 10:05:04 CDT 2023','Fri Aug 18 10:05:05 CDT 2023'), VersaCall_LKC, , false)
... 30 common frames omitted
Caused by: java.lang.Exception: Error executing system.db.runUpdateQuery(INSERT INTO group_table (ShiftStart, ShiftEnd, ShiftNo, Takt, ScheduledUnit, Target, Completed, DraggingUnit, WorkingDate, t_stamp)VALUES ('Fri Aug 18 06:00:00 CDT 2023','Fri Aug 18 17:00:00 CDT 2023','1','129','200','200','0','0','Fri Aug 18 10:05:04 CDT 2023','Fri Aug 18 10:05:05 CDT 2023'), VersaCall_LKC, , false)
... 29 common frames omitted
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: Conversion failed when converting date and/or time from character string.
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:265)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.getNextResult(SQLServerStatement.java:1662)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.doExecuteStatement(SQLServerStatement.java:898)
at com.microsoft.sqlserver.jdbc.SQLServerStatement$StmtExecCmd.doExecute(SQLServerStatement.java:793)
at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:7417)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:3488)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeCommand(SQLServerStatement.java:262)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeStatement(SQLServerStatement.java:237)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeUpdate(SQLServerStatement.java:733)
at org.apache.commons.dbcp2.DelegatingStatement.executeUpdate(DelegatingStatement.java:341)
at com.inductiveautomation.ignition.gateway.datasource.DelegatingStatement.executeUpdate(DelegatingStatement.java:80)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRStatement.executeUpdate(SRConnectionWrapper.java:867)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper.runUpdateQuery(SRConnectionWrapper.java:219)
at com.inductiveautomation.ignition.gateway.script.GatewayDBUtilities._runUpdateQuery(GatewayDBUtilities.java:251)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runUpdateQuery(AbstractDBUtilities.java:181)
... 27 common frames omitted
You're calling runUpdateQuery, not runPrepUpdate. I would strongly suggest you move to runPrepUpdate - in addition to giving you type-safe insertion (if you need to insert a datetime, you just use a java Date object as a parameter), it's also better for performance, in both Ignition and on the DB.
Tip: Use code formatting to have your error logs show up in a code window. It will apply a scrollbar when the number of lines exceeds a certain value and eliminates a pile of scrolling to get past the error log.
Thanks. I just tested this and that was the issue.
