Error writing "false" to tag
I already migrate a edge program from 7.10.9 to 8.0.2 in my UDT when i navigate start to appear this message.
What can i do to solve?
I have project in read/write mode
Captura
"false" isn't valid. Whatever script is trying to write to that tag needs to be updated, change it to "False"
I am looking and every place only let me choose false, not False. Do you know where should i look?
Also appears this error.
Thanks for your help.
Captura
I don’t know what to do? seems that Ignition Edge 8.0.2 is not working properly. It is possible? Can be that ignition try to write on tags preconfigured like only read? should i go to ignition 7.9
Does Ignition have checked this issue?
Have you tried editing the tag configuration to not be read-only? Are you sure you are writing a boolean False, not a string "False" ?
This tag has to be read only, but i try to put the session in read and write mode… and the problem persist.
Respect False… i do not know where is written false or False, can you rientate me? were should i look?
This forum is not an official support venue. We try to look at posts here in a reasonably prompt manner, but if you need specific technical help you need to contact support directly, ie email support@inductiveautomation.com or call in.
Session read-write mode cannot override a tag set to read-only. You simply can't write to such a tag at all.
In your script.
