I have a transaction group with 120 tags for a recipe(12 columns, 10 rows). The transaction group is setup as DB to OPC. I get the attached error when I attempt to push the values down to the PLC. I can manually edit each tag and the values in the SQLBrowser and the PLC receives the values. Any ideas?
bump just moved this here.
