I’m encountering a problem when trying to write tag values using a SQLTag Provider. I have a Realtime SQLTag Driving Provider running on a Linux server running Ignition 7.2.9. The tag providers are connecting to an Oracle database. I can create tags and write values on the gateway that is the driving provider. However, when trying to write tag values from a second gateway using a SQLTag provider the errors listed below are encountered and the values are not writter.
Is there something I am missing when configuring the Tag Provider?
Jeremy
Error returned by Designer:
Error writing to TestTag.Value: StatusCode[Severity=Bad,Subcode=Bad_InternalError,0x80020000]: Cannot coerce value ‘[0,Good]’ into type: class java.lang.Integer
The error displayed in the Console is:
java.lang.ClassCastException: Cannot coerce value
'[0,Good]' into type: class java.lang.Integer
at com.inductiveautomation.ignition.common.TypeUtilities.coerce(TypeUtilities.java:971)
at com.inductiveautomation.ignition.common.TypeUtilities.toInteger(TypeUtilities.java:980)
at com.inductiveautomation.ignition.common.TypeUtilities.coerce(TypeUtilities.java:726)
at com.inductiveautomation.ignition.gateway.sqltags.providers.DatasourceTagProvider.internalWriteValue(DatasourceTagProvider.java:109)
at com.inductiveautomation.ignition.gateway.sqltags.execution.AbstractTagDriver.write(AbstractTagDriver.java:487)
at com.inductiveautomation.ignition.gateway.sqltags.SQLTagsManagerImpl.write(SQLTagsManagerImpl.java:366)
at com.inductiveautomation.ignition.gateway.project.ProjectSettingsCache$ProjectDefaultTagManagerFacade.write(ProjectSettingsCache.java:456)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.SQLTags$ClientWriteOperation.run(SQLTags.java:377)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
