I am trying to export a folder full of 1555 tags. Everytime I export the folder I get the following error message..,..
I have some limited success when I try to do say 100 tags at a time, then when I do the next 100 I get the same error message
I still want to export the entire folder at once.
Looks to me like you have a tag somewhere that contains data that can't be serialized to json.
Doesn't matter how many tags you try to export at once, as long as one of them can't be exported, you'll get this error.
Did you do anything weird with one of your tags ?
It must have been something like that. I ended up exporting a "good" export of 100 of them and then used notepad ++ to change the tags manually all at once. It took a little extra time but probably not as much time as finding the one part of that export that had an issue. Thanks for the help!
